I have a digital caliper/gauge: it works with FTDI interface and digimatic (or very similar) protocol. It is connected via usb port. I can connect it correctly, and I can read it with programs like GtkTerm or similar. I can also read the instrument via stty, but only physically pressing the button on the caliper which allows to send some signal on D+ or D- line (I don't know which one exactly....).
Is there a way (in bash for example) to send a signal on the usb lines D+ D-? The electrical specifications of the instrument says that the needed signal should be a low voltage to the "request line" for some milliseconds; which is one of the tho data lines in the usb connector, I suppose....
The tools which showed to be able to read the caliper / gauge made use of commands like DTR / RTS; can stty alone send such signals to usb ports??
