I'm planning on using radar to count car traffic on a slow speed road. What I'm wondering is if I should expect doppler radar to be good enough to get an accurate count? Alternatively I could also use FMCW radar in addition. Will adding FMCW give me much added benefit over just doppler?
  • \$\begingroup\$ Without any evidence I'm going to say it should be enough to get the same numbers as those air pressure driven traffic counters. Narrow beam straight across the road. Arguably some cars won't get counted due to overlap but the numbers should be fairly within range. \$\endgroup\$
    – Passerby
    Oct 24, 2021 at 19:20
Yes.
Your problem "counting traffic" is essentially a target tracking problem: just seeing the speeds of targets reflecting, or their distance, or both, will not allow you to count cars; you will need to be able to track whether something is a new car or just the same care as in the last radar estimate, moved a bit further.
This can be done on dopplers alone. Of course, theory tells us the more useful data we have, the better we can estimate, but seeing that cars probably don't change speed drastically between two radar periods (which probably are less than milliseconds apart), a simple "gating" filter (observe something with a given doppler the first time, calculate a sensible upper and lower deviation from that doppler, and if that is hit, assume it's the same car, if not, add a new car to your tracking).
What's bad about doppler-only is that you won't be able to track two cars driving at the same speed with little distance; that's something you'll see quite commonly in a slow-speed street.
  • \$\begingroup\$ Beaming the radar diagonally across the road or diagonally down on the road might help narrow the measurement zone enough to sense individual cars. In other words, it might allow detection of the gap between cars. \$\endgroup\$
    – Transistor
    Oct 24, 2021 at 17:45
