21
Can anyone point me to a tutorial for electronic noobs that explains how to use op-amps and what I can do with them, besides amplification?
11 Answers 11
17
Hyperphysics has a pretty good section about opamps:
  • \$\begingroup\$ +1 This is a great link... a definitive list of everything you can do with an op amp. Thanks. \$\endgroup\$
    – BG100
    Jan 4, 2011 at 17:48
    \$\begingroup\$ Hyperphysics in general is made of multiple flavors of win, with a sprinkling of awesome and a dash of genius. Between that and wikipedia the first 2 years of college are pretty much covered. \$\endgroup\$ Apr 4, 2012 at 15:34
  • \$\begingroup\$ First two years of college except the sex. \$\endgroup\$ May 25, 2012 at 15:18
  • \$\begingroup\$ @JoeStavitsky: Is there an overview/index page of Hyperphysics somewhere except the directory listing? \$\endgroup\$
    – Rev
    Aug 27, 2013 at 9:23
13
I know it's not all online, but the Art of Electronic by Horowitz and Hill is fantastic. It's basically the only book you need for the first 2 years of learning electronics (especially if you don't have any math requirements). The second edition of the book was published back in the late 80s and a lot of the example circuits using op amps are spectacular examples.
    \$\begingroup\$ Horowitz and Hill not Howe \$\endgroup\$ Dec 10, 2009 at 2:07
  • \$\begingroup\$ As someone in "the first two years of learning electronics", I must say that it's not necessarily for beginners. Some people may grasp it intuitively, but for the rest of us it's a concise reference. \$\endgroup\$ Apr 4, 2012 at 15:32
7
Try Opamps for Everyone (warning -- large pdf, and some TI bias)
It has lots to teach, covers beginning to somewhat advanced topics, and it's free.
There are a couple of very good tutorials at Analog Devices and Texas Instruments. The TI one is called "Handbook of Operational Amplifiers".
Op amp Cookbook
This book is considered to be a key text on the subject. I dont think there is an online version available... £30 (where I come from) is around the "reasonable" price range for such books.
  • \$\begingroup\$ I will add my vote. It can be found on abebooks as well. Excellent book, covers how to do all manner of analog math with op-amps. Linearization, converting linear to logarithmic, etc. \$\endgroup\$ Dec 7, 2009 at 1:38
Falstad Falstad Circuit index has an excellent Java applet that allows you to do virtual prototyping with various types of circuits.
Has a nice section on Op amps, whats great is the built in O'scope, volt and current meters. Right clicking on a template component in the applet brings up menu where you can experiment/substitute with different values, add remove components.
  • \$\begingroup\$ I've just discovered this app. It's great ! \$\endgroup\$
    – JonathanD
    Mar 13, 2010 at 18:55
Check out: http://www.opencircuits.com/Op_amp
This one helped me a lot for a Devices class which included op-amps. Really good animations, and covers most types (inverter, differentiator...) needed for a starting point.[link text]
http://electronics.wisc-online.com/Search.asp?search=op+amp
[1]
I always simulate my op amp and other analogue circuits with SPICE before building and testing them. Free SPICE implementations are available, and many PCB packages include it.
  • 5
    \$\begingroup\$ It's no use simulating if you don't know how to use them. \$\endgroup\$ Jun 11, 2011 at 15:16
  • \$\begingroup\$ Why the downvote? It helps one learn how to use them without wasting time building hardware that doesn't work. SPICE packages generally have plenty of examples of op amp circuits. \$\endgroup\$ Jun 11, 2011 at 16:18
The "IC Opamp Cookbook" paperback was ~THE~ standard for hobbyist electronics back in the 80s. Still a good reference.
Op Amps for Everyone (2.0 MB PDF) by Texas Instruments is a very good reference. It covers almost any aspect you might need. Even single supply opamp techniques.
  • \$\begingroup\$ Duplicate of [this answer \$\endgroup\$
    – Kortuk
    Aug 27, 2013 at 13:02
