For a NMOS, the transconductance gm is defined as id/vgs at a fixed VDS. However when we calculate the small signal gain of a common source amplifier, we use vds = -id x RD and then vds = -gm x vgs x RD.
Why we can substitute id as gm x vgs? according to the definition of gm, it is defined as id/vgs at a fixed VDS, but here the VDS has the change in vds in the equation.
A similar issue is that the output resistance ro, defined as id/vds at a fixed VGS. but why we can still use ro for calculation when the equation contains vgs?
Do I miss anything here?
    \$\begingroup\$ I think this is because, these are small-signal quantitites, i.e. they apply for a given operation point and for small deviations thereabout. \$\endgroup\$
    – tobalt
    Oct 25, 2021 at 7:08
  • \$\begingroup\$ Also questions like this would be more readable, if you used MathJax notation, i.e. instead of gm x vgs, write \$g_m V_{gs}\$ to obtain: \$g_m V_{gs}\$ \$\endgroup\$
    – tobalt
    Oct 25, 2021 at 7:23
Why we can substitute id as gm x vgs?*
Because, if you draw the small signal equivalent model of the common source:
Image source.
you should "see" that \$i_D = gm * v_{GS}\$.
Note how I write \$i_D\$ and not \$I_D\$.
\$i_D\$ is the small signal current so actually the derivative of \$I_D\$.
\$I_D\$ is the actual drain current that you would calculate with for example: \$I_D = K_p \frac W L (V_{GS}-V_t)^2\$)
Yes correct BUT you should separate:
small signal parameters (\$gm, i_D, v_{GS}\$) and
large signal parameters (\$I_D, V_{GS}\$)
The small signal ones are the ones where we:
  • assume the transistor is biased at a certain operating point (a certain \$I_D\$ and \$V_{GS}\$)
  • assume that we apply small signal (\$v_{GS}\$) so that the circuit operates in a linear fashion (no distortion)
Then we can use the small signal model and parameters.
