I'm trying to install the MightyCore bootloader into an ATmega32A-PU chip but I'm getting the following error when I press the "Burn bootloader" button on Arduino IDE:
Arduino: 1.8.16 (Linux), Board: "ATmega32, Yes (UART0), EEPROM retained, Standard pinout, BOD 2.7V, LTO disabled, External 16 MHz"
/home/ian/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino18/bin/avrdude -C/home/ian/.arduino15/packages/MightyCore/hardware/avr/2.1.3/avrdude.conf -v -patmega32 -cstk500v1 -P/dev/ttyUSB0 -b19200 -e -Ulock:w:0x3f:m -Uefuse:w:{bootloader.extended_fuses}:m -Uhfuse:w:0b11000110:m -Ulfuse:w:0b10111111:m
avrdude: Version 6.3-20201216
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/home/ian/.arduino15/packages/MightyCore/hardware/avr/2.1.3/avrdude.conf"
User configuration file is "/home/ian/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega32
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 4 10 64 0 no 1024 4 0 9000 9000 0xff 0xff
flash 33 6 64 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
efuse 0 0 0 0 no 0 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
calibration 0 0 0 0 no 4 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Error while burning bootloader.
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x00ff00
avrdude: Expected signature for ATmega32 is 1E 95 02
Double check chip, or use -F to override this check.
avrdude done. Thank you.
The chip was bought from AliExpress. The front label on the chip says:
ATMEGA32A PU 1323
and the back:
3W0647-35460K 1-P1323 e3
I've setup an Arduino Nano as an ISP by loading the example sketch from Arduino 1.8.16 and uncommented the #define USE_OLD_STYLE_WIRING
, compiled and uploaded to the Arduino Nano. Everything seems to be working correctly, the blue LED blinks slowly.
I then proceeded to wire everything according to the comments on the Arduino sketch. Here is a picture of my setup:
To burn the bootloader, I've chosen the following settings on Arduino IDE:
Checks I've made before burning the bootloader:
- checked that all the pins on the atmega were connected to the protoboard with a multimeter and a spare jumper wire;
- voltage between 5V and GND on Nano was 4.7V; the same voltage was read between 10-11 and 30-31 on the atmega;
- I don't have an oscilloscope, but the crystal was working on another application with a similar chip (atmega32-16pu).
Additional info: most of my attempts the device signature was 0x00ff00, but sometimes it also read 0xff00ff.
Is there anything else I can do to make this work?
