I have a 3.3VDC microcontroller (based on Nordic nRF52840) with digital inputs which I need to interface to a device that outputs slow pulses (1 second) via an "open collector output".
The device's manual describes its output as follows: "The pulse output is an electronic switch that operates much like an ‘open collector’ transistor." The output can be configured as Form A or Form C, and the pins are labeled K (Common), Y (normally open) and Z (normally closed).
The documentation provides the following ratings for these outputs:
- Outputs are isolated from ground and each other.
- Outputs are rated for DC only, from 3.0 volts to 30.0 volts. Observe polarity.
- The circuits will sink up to 15 milliamperes (DC) for Form-C outputs and up to 5 milliamperes (DC) for Form-A outputs.
- All electronic pulse outputs incorporate opto-isolators to electrically isolate the device circuitry from the devices receiving the pulses.
This is all the info I'm provided by the manual.
I need to know the proper way to connect this output to my MCU.
Here's the way I think it could be done, using a pull-up resistor, but I'm not sure about it. As I understand it, the open-collector output means the output is basically floating when off, allowing the full 3.3V to appear at the MCU connect point. Then when the output turns on, it shorts Y to K, thus dropping the 3.3V across R1, leaving 0V at the MCU connection point.
Is this correct? Am I missing something?
