I'm designing an audio signal frontend to take an electric guitar analog output and deliver it to an ADC channel on a microcontroller. The µC/ADC are 3.3V devices (although there is a 5V regulated voltage source available on its carrier board). The purpose of this frontend is to take the AC waveform coming out of the guitar, which has a P-P voltage dynamic range between a few dozen mV and up to 1V, offset the signal by 1.65V (half the ADC range), amplify it up to the ADC's rails, and apply an antialiasing lowpass filter beyond 20kHz.
I would prefer to use a low voltage, single supply, rail-to-rail amplifier that can directly run off the MCU's 3.3V supply without me having to mess around with additional voltage clamp circuitry or even a dual supply which would require a charge pump. I want to use only components that I have on hand and not buy anything extra. The only single-supply 3.3V amp that I have is the LT6200-10 (product page; datasheet). I have 2x units of this IC, enough to create one preamp and one active filter.
Before printing and assembling the PCB by hand, which always runs the risk of damaging components, I wanted to simulate the preamp portion to make reasonably sure that it will do what I want. Since the heart is an LT part, I begrudgingly used the awful LT-SPICE simulator to capture the schematic and run a transient simulation. Here are the results.
LT6200-10 preamp circuit schematic LT6200-10 preamp circuit simulation graph
  • [OK] The input waveform V(in) is a steady 500 Hz 400mV sine wave.
  • [OK] The bias voltage divider V(divider) emits a clean 1.65V DC.
  • ---> The noninverting input V(ninv) to the amp appears to be centered around ~2.3V rather than at the expected bias voltage of 1.65V.
  • ---> The output waveform V(out) is clipped at exactly 3V and bottoms out at around ~1.1V rather than near 0V.
At first I suspected that the -10 variant of the LT6200, which, according to the datasheet, appears to be intended for gains of >10, may not be compensated for the low gain of this circuit. So, as a test, I replaced the LT6200-10 with the regular LT6200 and re-ran the simulation. However, I observed an identical graph.
I think the fact that V(ninv) is offset 650mV higher than expected is a huge giveaway. As another test, I disconnected the noninverting input and re-ran my simulation. I was struck by the fact that V(ninv) now is perfectly centered around the bias voltage:
So it seems that the input to the amp – which is, presumably, at a very high impedance – nevertheless dramatically alters the incoming signal. My analog knowledge is pretty weak so I can't understand why this is happening. I know that an ideal amp will always attempt to keep the inverting and noninverting inputs at the same voltage, so this is a hint to me on what's going on, but I'm stuck in trying to do further circuit analysis. I've fiddled a bunch with various orders of magnitude for all of the surrounding passives but nothing seems to cause a trend towards my intended behavior.
What am I missing? Is my topology wrong, or maybe one of the component values? I'm equally interested in filling the gaps in my theory knowledge as I am in a practical solution to this problem so that I can actually build the circuit.
Thanks for any help!
  • \$\begingroup\$ I think your problem lies in the input current of the op-amp and the crazy high value for R6. I don't have a good enough grasp of those things to make a good answer, though, so I'll wait and see how someone else explains it. \$\endgroup\$
    – JRE
    Oct 27, 2021 at 9:28
  • \$\begingroup\$ @JRE I tried a number of wildly different values for R6 as part of my experimentation and, while bringing it down does reduce the V(inv) offset somewhat, the input signal now starts to leak into and affect the bias voltage. I can reduce R8 and R9 to compensate but all of this causes the system gain to be quite low. Reducing R3 to try to increase gain doesn't do much.... I feel like I'm trying to play whack-a-mole. \$\endgroup\$
    – pion
    Oct 27, 2021 at 9:36
  • \$\begingroup\$ To achieve the typical value of 10uA for input bias current you're going to need 100V across R6! So what if the input leaks into the bias voltage, it's not used for anything else. \$\endgroup\$
    – Finbarr
    Oct 27, 2021 at 10:53
  • \$\begingroup\$ The other issue is the use of R1/R2 in the feedback loop, which will mean the op amp output is going to to be offset above the bias voltage, hence the clipping at the top of the waveform. \$\endgroup\$
    – Finbarr
    Oct 27, 2021 at 11:06
  • \$\begingroup\$ First of all, is that your opamp (LT6200-10) is not unity-gain stable. You need to have R3/R2 > 10. And your second biggest problem is the input bias current (8µA) and R6 in the range of megaohms. Do you really need such a high input impedance? Try lower R6 to arond 75k. Also why C3 has such a smal value? \$\endgroup\$
    – G36
    Oct 27, 2021 at 14:36
Your big problem, I am pretty sure, is input bias current, the main reason for your output offset. When you disconnected the opamp's non-inverting input, the potential you found at the bottom of R6, and the right end of R5 was \$\frac{3.3V}{2}\$ because there is no longer any current being drawn via those resistors. The voltage across them became 0V, and the potential at those points would be the same as the potential at the junction of the divider R8 & R9.
According to page 4 of the datasheet you linked to, input bias current (when the opamp's inputs are both at \$\frac{V_{CC}}{2}\$, which would be the case if your circuit was working properly) is typically 10μA. This is DC quiescent current, which has to come via R5 and R6. 10μA through \$R_6 = 10M\Omega\$ would develop:
$$ V_{R6} = 10\mu A \times 10M\Omega = 100V $$
Obviously that's not possible, so what is happening is the system is settling at some quiescent level where input bias current is still significant, enough to drop a volt or so across R6. However, this does illustrate why \$R_6 = 10M\Omega\$ is problematic for this particular opamp.
Whatever biasing system you employ, it will have to source about 10μA, and this might be impossible with a simple resistor divider, while maintaining a high input impedance. Imagine a single resistor R from \$V_{CC}\$ to the opamp's input. It shall source 10μA to the input, and drop \$\frac{V_{CC}}{2}=1.65V\$:
$$ R = \frac{V}{I} = \frac{1.65}{10\mu A} = 165k\Omega $$
That's the upper limit of any resistance that can participate in a biasing divider for this opamp's input.
I have one suggestion to overcome this problem, which doesn't involve another opamp, and that is to use an emitter follower to buffer the input signal, and bias it at the same time:
The same problem exists at the opamp's inverting input. That input will also require 10μA, which must be sourced by the opamp's output via the feeback resistor R3. I fear that 100kΩ is way too large, developing \$10\mu A \times 100k\Omega = 1V\$ additional offset. R3 should be something that would pass a milliamp or so at full swing, a current that dwarfs input bias current. Something of the order:
$$ R_3 = R_4 \approx \frac{1V}{1mA} = 1k\Omega $$
I notice that R1 and R2 drop the opamp's output potential towards ground by 10% or so. This may not seem like a problem, because opamp negative feedback will cause the output to rise accordingly in compensation, but a side effect of this is that the opamp's quiescent output level is now above the power-supply mid point, and will contribute to asymmetrical clipping.
I don't know what R1 and R2 actually do, so unless you need them for some reason I am not aware of, you should get rid of them. Let the output operating point sit half way between the power supply potentials.
Edit:
I just noticed that the opamp inputs may actually source 10μA of bias current (the figure in the datasheet is -10μA), which invalidates the circuit above.
In that case, you can switch the biasing resistors, and use a PNP instead:
Each considered op amp will tend to have strong points in its various parameter specifications but each op amp will also have its weak points. It is not possible to have an op amp that is a strong performer in all aspects of its capabilities and so when selecting an op amp for a particular application it is a trade off and the final chosen device would be chosen based upon which of its parameters are required to be high performance.
Your chosen op amp is a strong performer on GBW (bandwidth capabilities) but is a weak performer on input bias current. Your audio application requires a fairly small bandwidth but needs to be a strong performer on input bias current which is required to be a low value so as to cause low output offset when it flows through the resistances connected to the op amp's inputs. Therefore I would suggest that you have made a poor choice of op amp in the LT6200 for your application.
You could have a look at the LMC6482AIN which has rail to rail input and output, will work down to a supply voltage of 3V and, importantly, has low input bias currents. It is a fairly common op amp.
A typical guitar amplifier is required to have an input resistance of about 1M omhs and so I would suggest R6 = R7 = 2M because the input resistance = R6//R7.
To keep the bias voltage steady, increase the value of C1 to say 22uF which will largely reduce the output resistance of the potential divider whilst providing good supply rail filtering.
The gain of the amplifier is (R3/R4)+1 = 2
C3 provides a dc block and low frequency roll-off, the -3dB lower cut-off frequency being = 1/(2 * pi * R4 * C3) and so C3's current value is way to low as it is reducing the amplitude of signals below about 9kHz and needs to reduce signals below 20Hz.
C5 reduces the amplitude of high frequencies and so can improve stability as well as reducing high frequency noise. The -3dB upper cut-off frequency caused by C5 is in the region of the frequency given by 1/(2 * pi * R3 * C5) and so C5's current value is too high as it is reducing the amplitude of signals above about 9kHz, a figure that needs to be increased to say 50kHz. Note this equation is just an approximate equation for the -3dB frequency.
Another issue, mentioned by finbarr, is that the current flowing in R2 is causing a voltage drop across R1 causing the op amp's actual output to go more positive than if you removed R1 and R2 which I would suggest you do to bring the op amp's output down a little which will reduce the likely hood of positive clipping.
Your simulation doesn't actually make sense to me. At 500Hz and the low frequency roll-off, caused by the low value of C3, I would expect your amplifier's gain to be about unity (one). Maybe the op amp isn't working properly because of the high input bias current combined with the high value of R6.
  • \$\begingroup\$ An electric guitar feeds a preamp made with an audio opamp, not a radio frequency opamp. The input resistor is usually 1M to 3M, not 10M. With such a low power supply voltage you do not want the R1 and R2 attenuator at the output that is biased to ground. Your value for C3 is so low that it cuts all frequencies below 8.9kHz, use at least 22nF when R4 is 100k. \$\endgroup\$
    – Audioguru
    Oct 27, 2021 at 21:51
