I know everything about this topic but I don't know why ground is meaningless in high speed circuits. So basically in high speed circuits these are the factors we need to consider-:
Decoupling caps
Coupling/Crosstalk
Bandwidth
Ground bounce
Impedance matching
Timing
I know about routing signal traces, we should keep check of these things-:
Distribution of signal and return
Coupling
Common impedance
Trace impedance matching
Trace density
Transmission line concerns(Basically stuffs of high speed design)
Also I know that in low speed, return current goes the path of least resitance whereas in high speed circuits, return current returns to path of loweset inductance.
Similarly, I know there should not be slot in ground plane(Although I don't know why, maybe because it increases loop area). But I am not able to conclude why ground is meaningless in high speed circuits and why return current path is more important?
