I need a button (or a button couple) that acts as a switch in emergency such that when one pushes the button, the +12V supply line below becomes an open circuit even he releases the button. But I also want the user (after fixing the issue etc.) can push the button (or button couple) and the supply line is closed and device is powered again.
What type of button/switch or latch can provide such functionality?
Not surprisingly, these are called "emergency stop switches" and they are readily available.
For safety reasons, however, most are typically reset not by a second push, but by twisting or pulling instead. However dual-button and rocker variants are also available, although they are usually more expensive, especially those with built-in fuses.
