I have a question about an idea of mine, concerning the split up of a 5 V supply voltage into a 3.3 V and a -1.7 V voltage. My circuit has to be as efficient as possible and therefore I don't want to use a combination of a simple 3.3 V voltage regulator and a voltage conversion IC (like the ICL7660). The negative voltage is only used as negative supply voltage for a precision operational amplifier whose output voltage will never be under -100 mV, but for sure will be negative too.
My idea was to use something like this, to stabilize the important 3.3 V voltage for the microcontroller on my board and leave whatever difference between the supply voltage (normally 5 V, but can vary because of battery usage) and the 3.3 V remains as negative reference voltage: Sorry, I don't have a better picture at the moment, but I hope you get the idea
(The used parts are only symbolic, I didn't take the time to find exact components for my circuit and needs, before I know the concept even works)
I don't need high currents, like I said it is a fairly low power circuit which this supply-circuit should power. Would this be a feasible option or did I miss/overengineer it too much? I tried simulating it and the results looked promising in the sense, that I could vary the supply voltage and load resistance (not in the picture) to a certain degree and everything looked stable.
So my questions now are:
  1. Can this concept work or what flaws can you think about?
  2. Will this be more efficient as the voltage regulator/voltage inversion-approach? Like I said I don't really care how big my negative voltage reference voltage is, because the op-amp will never go rail-to-rail on the output.
  3. Building on the last question, is it even a good idea to supply an op-amp with an unsymmetrical supply voltage, like 3.3 V and -1.7 V in my case?
  4. Any tips and tricks you could help me out with or do you have a better or easier approach in mind? Please let me know if that is the case.
  • \$\begingroup\$ since you did not draw a real circuit i did not bother to analyze the circuit :) but yes, the concept of splitting a power supply by creating a new rail in the middle is fine. And doing it with an op-amp buffer is fine. I think there are better ways to create the Vcc-3.3V reference voltage for the input to the buffer. \$\endgroup\$
    – user253751
    Nov 1, 2021 at 14:50
  • \$\begingroup\$ You can set the circuit ground point anywhere you like, but it will not be very efficient if you use linear regulation to adjust the voltage levels. \$\endgroup\$
    – tobalt
    Nov 1, 2021 at 15:10
    \$\begingroup\$ Building on the last question, is it even a good idea to supply an op-amp with an unsymmetrical supply voltage, like 3.3 V and -1.7 V in my case? To the opamp, it looks like you're powering it with 0 V and + 5 V. Which is not an issue for an opamp that can work with a 5 V single supply. My point: the opamp doesn't "know" you're making +3.3 V and -1.7 V and the opamp doesn't care either. So yes, this will work. \$\endgroup\$ Nov 1, 2021 at 15:11
  • \$\begingroup\$ @user253751 thanks for the comment. may you elaborat about a better way to create the vcc-3.3v-reference? I know that it is for sure not perfect, because using all those different op-amps is for sure not the most efficient way. I couldn't think of a better way but would appreciate it, if you could provide an approach :) \$\endgroup\$
    – Rata
    Nov 1, 2021 at 15:56
  • \$\begingroup\$ You can make it work; but it won't have any effect on energy efficiency. \$\endgroup\$
    – user16324
    Nov 1, 2021 at 16:08
Yes, it's fine.
Note that if you connect 3.3V stuff between the +5V and +1.7V rails, current goes into the 1.7V rail towards ground. You need to be aware of this because most voltage regulators are only designed for current to go out of them. Op-amps work both ways so you don't have this problem.
Note that all of that current goes through the op-amp. Make sure the op-amp is rated to handle all of the current that goes through your 3.3V stuff. This is a linear type of regulator - excess voltage is dissipated by creating heat. So make sure the power dissipation of the op-amp is okay too.
A minimum of 1.7 5.0ths, which is 34%, of the power gets wasted as heat. Whether that's okay for you, I can't say. It's up to you. You might be able to do better with some type of switching regulator.
If the amount of power isn't very much, it might not be a problem.
Op-amps don't actually know where 0V is. No circuit knows where 0V is. Op-amps, though, don't even have a 0V pin. They need a voltage that's higher than all your inputs and outputs, and a voltage that's lower than all your inputs and outputs. As long as all your input and output voltages are between the + voltage and the - voltage, with some margin (check the datasheet), and the + voltage and - voltage aren't too far apart (check the datasheet) this isn't a problem.
The op-amp to create the voltage is fine, however, the way that you get the 1.7V reference voltage for the op-amp input is unnecessarily complicated. You use a 3.3V regulator to get 3.3V above the ground rail, and then you use op-amp math to "flip it upside down" to get 3.3V below the +5V rail.
For one thing, these regulators are designed to handle reasonable amounts of current and you are only demanding a tiny trickle. Some regulators require a minimum amount of load or else they won't regulate properly.
For another thing, it's just overly complicated.
Make a voltage divider between +5V and ground. But instead of a resistor, in the top half put a 3.3V shunt voltage reference (like this one but not this exact one).
An alternative is a 3.3V Zener diode. However low-voltage Zener diodes actually aren't that accurate as the voltage changes with the current. If you use a Zener diode you can put a trimpot in the bottom half and adjust the current while checking the voltage with your multimeter.
Of course you can also just make a plain old resistor divider. 1.7V is 1/3 of 5.0V so the top resistor should be twice the bottom one. I just assumed you wanted to regulate the 3.3V in which case you can use one of the other two methods.
Anyway, now that you have a voltage divider with 3.3V in the middle, just connect the middle of the voltage divider to the input of your op-amp voltage follower.
  • \$\begingroup\$ Thanks for the extensive answer. About the 3.3V voltage regulator, I knew that it was overkill but it was the first thing that popped into my mind and I actually searched for easier possibilities to create the 3.3V reference. I just used it primarily because the model was preinstalled into LTspice and I wanted a proof-of-concept. But now that you gave me an idea for a better alternative and now knowing it can work, I will look into finding a better way. Just one last thing, what did you mean by "A minimum of 1.7 5.0ths", could you clarify? \$\endgroup\$
    – Rata
    Nov 1, 2021 at 17:16
  • \$\begingroup\$ @Rata I mean 1.7 out of 5.0, 1.7 divided by 5.0, if you split up the thing into 5.0 parts then 1.7 of them. Of course I could write 1.7/5.0 but where's the fun in that? \$\endgroup\$
    – user253751
    Nov 1, 2021 at 17:20
  • \$\begingroup\$ I have to admit i can't follow you. I understand now what you meant, but why would 34% of the power go up in heat? I understand that a while using a voltage regulater 34% of the power go to waste and therefore I tried another approach. But should't in my case only minimal power go to waste, i still have the 1.7V voltage drop over the regulator but considering that the current should be absolutely low, there shouldn't be much power loss or what am I missing something? Same while using a shunt voltage reference/zener diode, do I have other power losses then the one in the diode/resistor? \$\endgroup\$
    – Rata
    Nov 1, 2021 at 17:38
  • \$\begingroup\$ @Rata you have a 1.7V drop over an op-amp \$\endgroup\$
    – user253751
    Nov 1, 2021 at 17:39
  • \$\begingroup\$ So i won't have a better efficiency than going with a voltage regulator, but at least i don't have to introduce another component which draws power for generating a negative voltage reference, correct? \$\endgroup\$
    – Rata
    Nov 1, 2021 at 17:52
