I want to route some tracks directly in the PCB file in Altium, So there is still no Netlist available.
So what rule/rules should I change to route pads directly, without applying the clearance rule between the track and the pad for the newly created nets?
    \$\begingroup\$ Ascribe common net names to connected parts. Or better still, do that in the schematic level and do the job correctly instead of looking for non-ideal workarounds. \$\endgroup\$
    Commented Nov 2, 2021 at 14:30
  • \$\begingroup\$ This is not applicable due to the number of items to be connected. No schematic is present. \$\endgroup\$
    – Bavly
    Commented Nov 2, 2021 at 14:40
    \$\begingroup\$ I found another solution which is to set the clearance between the track and pad to -1mm. and then (Design ---> configure physical nets). This will do the job perfectly. \$\endgroup\$
    – Bavly
    Commented Nov 2, 2021 at 14:41
  • \$\begingroup\$ Fact based answer was provided. Requirement was clear. Close-Open \$\endgroup\$
    – Russell McMahon
    Commented Nov 5, 2021 at 10:47
Disable Online DRC.
Preferences -> PCB Editor -> General -> Editing Options -> Online DRC = unchecked.
You should really create a schematic, even if there's only two parts on your board. In the time it took to write this question, you could have made your schematic. It's amazing how a seemingly simple project can go awry. By creating a schematic, you don't need to compromise design rules which are there to help you create a board without spacing and wiring errors. Plus, when you revisit this project in a year, a schematic will make more sense than a routed PCB.
This is a couple of years old, but I came across this when searching for the same answer, I didn't find one, but I did come across a way of doing it that doesn't involve changing settings or creating rules that are in general not good.
  1. place a trace from the first connection to somewhere between the connections.
  2. place a trace from the second connection to somewhere between the connections.
  3. drag the copper from one connection onto the other.
There are two ways:
  1. Use Place - Line (or other shapes as you like) to draw arbitrary copper. It will be placed with Net = 'No Net'. Note that primitives will pick up nets when dragged or pasted onto other net objects (pads, existing traces, etc.), and will yield a shorted unconnected copper violation (with normal settings).
  2. Design / Nets / Edit Nets, and add new custom nets. You can construct the netlist manually this way (or edit a plaintext netlist and import it, just as well). Assign pads to nets in the dialog, or via their Properties. Route as usual; design checks will be meaningful.
  3. Add a schematic to the design, use generic symbols (headers say) if you have to, match up footprints and assign pins (you may need to create a PcbLib from the PcbDoc to be able to assign footprints), and continue as usual.
Note, if using schematic, once a synchonizable design is prepared, in PCB check Project / Component Links, and match up respective symbols/designators/footprints. This avoids renaming, swapping or deleting and re-adding that may occur with unsynchronized parts (part IDs not matched).
