I have the following plans: I want to use a 555 timer in astable mode to light up 5 different LEDs. These should light up one after the other (i.e. not two at the same time). After that, there should be a pause for the same period of time as for the lighting of an LED. Then, it starts from the beginning again.
I already checked a little today: I need a ring counter. Unfortunately, I don't have one in the library. I'm using PSpice for TI 2020, so I don't have all imaginable parts. Could you suggest how I can use simple means to build a ring counter with 6 outputs? I don't expect you to solve everything, I'm just asking for ideas so that I can start.
I would like to use a typical 9V battery as the source. (If that's too much, I'll just use something smaller or a voltage divider. That shouldn't stop us.)
I can do that with the timer. Did you see in the last thread. How fast can the timer actually get, in terms of frequency?
However, if you have a completely different approach, always give me your opinion! :)
... what happens after the pause? \$\endgroup\$
