embedded and BSP newbie here. Recently I found a term named "gpio bank", but I cannot find good resources from google.
  1. What's it?
  2. difference of gpio bank and gpio controller?
  3. difference of gpio bank and pin
linux kernel code sample:
    soc->bank_num = of_irq_count(child);
    if (soc->bank_num == 0 || soc->bank_num > GPIO_MAX_BANK_NUM) {
        dev_err(&pdev->dev, "Invalid gpio bank(irq)\n");
        return -EINVAL;
    for (i = 0; i < soc->bank_num; i++) {
        res = platform_get_resource(pdev, IORESOURCE_MEM, i);
        if (res == NULL) {
            dev_err(&pdev->dev, "no mem resource for gpio[%d]!\n", i);
            return -ENXIO;
        soc->regbase[i] = devm_ioremap(&pdev->dev,
                        res->start, resource_size(res));
        if (soc->regbase[i] == 0) {
            dev_err(&pdev->dev, "devm_ioremap() failed\n");
            return -ENOMEM;
    \$\begingroup\$ These terms do not have a standardized meaning. You need to tell us where you found the term used. \$\endgroup\$ Nov 12, 2021 at 2:53
    \$\begingroup\$ In an FPGA, an I/O bank is a group of pins that share one or more attributes, the most common one being the I/O supply voltage. All pins in a given bank use the same supply voltage, and must be connected to external devices accordingly. \$\endgroup\$
    – Dave Tweed
    Nov 12, 2021 at 3:03
    \$\begingroup\$ @ElliotAlderson Hi, add sample codes \$\endgroup\$
    – Chen Li
    Nov 12, 2021 at 3:11
  • \$\begingroup\$ Looks like Linux kernel source code. But it looks like something specific to the SOC driver. The Linux kernel doesn't have a concept of GPIO banks \$\endgroup\$
    – user253751
    Nov 12, 2021 at 13:44
GPIO = General Purpose Input Output, referring to pins that send and/or receive single bits of digital information (high/low voltage).
A GPIO 'bank' is a group of GPIO bits that can be accessed simultaneously by the CPU or DMA. The number of bits in a group is usually limited by the size of the internal data bus, so for example an 8 bit MCU with 24 I/O pins would need at least 3 GPIO 'banks'. Sometimes the bits are split into more banks because some work at different voltages or have alternate functions, or because the particular package doesn't have enough pins to bring out all the bits in a group.
A GPIO 'controller' is a circuit in the MCU that controls the operation of GPIO pins. The term is typically used in sophisticated I/O systems which may need to perform operations independently from the CPU. Simple systems often just have control registers which the CPU writes to for configuring pin direction etc.
GPIO pins on microcontrollers and FPGAs are often grouped together in what is sometimes referred to as a "Bank".
All the pins within a bank will have their own power supply pin/s. So one bank could be using 3.3v logic while another could use 1.8v logic, for example.
    \$\begingroup\$ I assume your intention was to refer to different logic levels? \$\endgroup\$
    – po.pe
    Nov 12, 2021 at 8:55
  • \$\begingroup\$ @po.pe - thanks for alerting me to the typo. \$\endgroup\$ Nov 12, 2021 at 17:00
I've never had to use this term, so I looked it up and found many good resources.
https://docs.microsoft.com/en-us/windows-hardware/drivers/gpio/partitioning-a-gpio-controller-into-banks-of-pins
 Typically, a GPIO controller driver chooses to partition a GPIO controller into two or more banks for one of the following reasons:
   The power state of the GPIO pins in a bank can be managed independently of the pins in the other banks.
   The total number of pins in the GPIO controller is greater than 64.
https://www.realdigital.org/doc/e5be4c80924046606f8a9db3103adb91 etc
There are 4 banks; banks 0-3. Banks 0 and 1 connect to the MIO interface and goes to external pins on the chip. Banks 2 and 3 Go through the EMIO and are routed to the PL fabric
Each bank is 32-bits wide, with the exception of Bank1 which is 22 bits wide. Each bank has the registers shown in the single channel diagram, and each bitfield of each register corresponds to a a GPIO channel. Bank 0 [31:0] maps to MIO [31:0], Bank 1 [21:0] to MIO [53:32], Bank 3 [31:0] to EMIO [31:0], and Bank 4 [31:0] to EMIO [63:32].
The registers are described below, [n] is the bank number
DATA_RO[n] Reads the input values of pins configured as inputs
DATA[n] Holds the output values of the bank.
DIRM[n] Configures which channels in the bank are outputs or inputs.
OEN[n] Enables Channels in the bank that are configured as output to be driven.
There are additional registers for configuring GPIO interrupts. These are covered in a seperate document.
