When I am trying to create a float variable in Keil to program STM32 it just crashes.
I had a look online and as far as I read it tries to use hardware floating point unit (which is not enabled and I don't want to use it).
If I want to use software based floatin point then I have to specify that in my compiler.
How do I do that?
In the Keil Compiler Options (ALT+F7 - Target tab) you can select Floating Point Hardware - Not used. That should solve the problem.
