I have figured out how to make a sawtooth VCO using a 555 IC , by using a current mirror.
The issues I am having is I can't make it stable at all. Its having random issues like it randomly changes frequency output or if I turn it off for awhile then back on it changes frequency output even if the input voltage on the current mirror stays the same.
So what components can I add to this circuit to make it stable enough? I need this circuit to be able to be able to keep the same frequency output with the same voltage input.
