Hello everyone!
We are working on a realisation of an optical modulator and have a doubt. Mr Noel Miller posted already a question, but it was suggested this community. I will repost his question because he have not an account here.
PS I have copied.
Question version 1. In lasercom we use mostly OOK or PPM modulation.
Theoretically I understand what the purpose of a modulator is and how it works (mathematically). How does a modulator look like in practice?
Input of the modulator is optical or electrical signal, depends on if modulator is first or optical source is.
In practice, modulator is a device with 100s part…
Could you as engineer explain what modulator is? How was it implemented? What is optical modulator?
For me as someone who works with mathematical model it is difficult to imagine.
EDIT 1
I have found we can modulate the optical or electrical signal. Modulation could be after or before a laser source. What is the difference? Are there advantages or disadvantages? Does it better modulate optical signal or electrical?
EDIT 2
I have the following realisation of the free space communication. The transmitter here are signal generator, driver, bias tree, laser diode, isolator and collimator.
How do the collimator and the isolator connect with laser diode? It seems they are connected via smth...
    \$\begingroup\$ For one special kind of optical modulation through electrical stimulation look up a Bragg crystal. But perhaps you are looking at electroabsorption? Or are you just having trouble with the entire idea of modulation? \$\endgroup\$
    – jonk
    Nov 15, 2021 at 7:48
  • \$\begingroup\$ @jonk I have a trouble with understanding of a realisation concept an optical modulator in practice. In practice, device is implemented as a set of cables and other details, right? It is not a set of math equations. How does optical modulator connect with optical source ( if we use External modulator) and with a telescope)? \$\endgroup\$ Nov 15, 2021 at 7:58
  • \$\begingroup\$ @Antonio51 theory of OOK modulation I understand. I need to understand its practical realisation \$\endgroup\$ Nov 15, 2021 at 7:59
    \$\begingroup\$ @AnnaKoroleva I'm all about telescopes. I built three -- two of them I designed as well. But the whole idea of modulation spans a huge range of related topics. It's not some tightly defined "thing." There's square wave modulation, sinusoidal modulation, frequency modulation, spatial modulation, and even a modest chopper-stabilized opamp uses modulation. And they don't have much in common with each other except a vague idea. It's like saying "percussion" and expecting everyone to think the same thing. They won't. So what's the astronomical application here? Rotating grids?? \$\endgroup\$
    – jonk
    Nov 15, 2021 at 8:05
  • \$\begingroup\$ @AnnaKoroleva Are we talking about something like this? I've no experience there. But now I'm curious. \$\endgroup\$
    – jonk
    Nov 15, 2021 at 8:16
In comments you said,
For moderate data rates (say, below 10 Gbps), and when high spectral purity is not required at the output, OOK can be as simple as turning on and off the power supply to the laser. This is called direct modulation.
For higher rates, or when the laser linewidth can't be compromised, the laser is usually allowed to run continuously and an external modulator device is used. This could be an electro-absorption modulator, in which the absorption of a material placed in the beam is controlled by an electrical signal. It could be a Mach-Zehnder modulator in which the beam is split, and one arm is phase-modulated so that when they are re-combined you have either constructive or destructive interference depending on the state of the electric signal controlling the phase modulator.
For any of these modulation techniques, the modulator itself is typically considered to be a single part. The driver that controls it is generally just an ordinary RF amplifier, which may involve 5 or 10 transistors. Certainly not 100's. The main requirements for this driver amplifier compared to other RF amplifiers is that it must be relatively broad-band (possibly requiring bandwidth down to DC), and linearity might not be particularly important.
  • \$\begingroup\$ I have found we can modulate the optical or electrical signal. Modulation could be after or before a laser source. What is the difference? Are there advantages or disadvantages? Does it better modulate optical signal or electrical? \$\endgroup\$ Nov 16, 2021 at 7:10
Those are fiber optic components, so they're connected by an optical fiber. The isolator prevents back reflections from the collimator from damaging the laser. The collimator is a lens and an air gap that takes the diverging laser from the fiber and creates a collimated beam. Together those components take a fiber-based laser and make it act like a free space laser.
