I'm reading documentation about this component: https://www.microchip.com/en-us/product/LAN7800 .
It is a Ethernet to USB 3.0 Bridge. In a documentation point appears this:
The USB functionality consists of five major parts. The USB PHY, UDC (USB Device Controller), URX (USB Bulk Out Receiver), UTX (USB Bulk In Transmitter), and CTL (USB Control Block).
The UDC is configured to support one configuration, one interface, one alternate setting, and four endpoints. Streams are not supported in this device. The URX and UTX implement the Bulk-Out and Bulk-In endpoints respectively. The CTL manages Control and Interrupt endpoints.
I'm reading USB Complete by Jan Axelson, and I have seen this table:
Where appears each of the four type transfer types on USB, and appears Bulk, Interrupt and Isochronous transfers as "streams", only control appears as message. If streams are not supported by the component, only can be used with control transfers or I'm understanding wrong the datasheet?
Thank you so much.
