I have an slave SPI device implemented within an FPGA (Basys 3). I have had problems to route the SPI clock signal provided by a master to my slave device through one of the board PMOD pins (see this post).
What the 'application' does is: the SPI master (MCU) sends data to the slave (FPGA), and each time a byte of data is ready, the FPGA reads it and dumps the byte value to an 8 LED array. I have tried this already using routing the SPI master clock directly to the FPGA slave, and it works.
Now I want to apply the 'oversampling' technique (as explained in the post above) to avoid routing a clock signal through a PMOD pin, which is a very bad practice as far as I know. Let clk be the clock generated inside the FPGA (100 MHz), then, what I have done (which I understand is a good practice) is:
  • Route the clock signal generated by the master SPI to an edge detector (within the FPGA, driven be clk).
  • Drive the slave SPI with clk as well, and check the output of the above detector in order to read/write from/in MOSI/MISO.
With the above design, the FPGA gets completely desynchronized. The value 'dumped' to the LED array makes no sense (it does work with the previous version, driving the SPI maste clock signal directly to the slave through a PMOD pin). I'm aware of the master device sends data with enough time between frames to not make the FPGA 'collapse' (I'm 100% sure about this because, as explained, the previous version I have works).
My SPI master device (which is an MCU) asserts the reset signal just after configuring the SPI master periph., so I'm sure that the problem is not that I reset the MCU and the slave is in a not valid state due to a previous SPI transaction not being completed.
I don't understand what I'm doing wrong. The code is below:
Main FPGA module
`timescale 1us/100ns
// This mismatch between send and receive data size is due to the 4 dummy bits the slave
// 'needs' to receive. I'm sure this works because I have tested it before trying to apply
// the 'oversmaling' design.
`define SEND_DATA_LENGTH 12
`define RECV_DATA_LENGTH 8
`define EN_WAIT_CYCLES_VAL 100
module spi_tb_fpga(CLK100MHZ, JA, LED);
  input wire CLK100MHZ;
  input wire [7:0] JA;
  output wire [15:0] LED;
  wire __fpga_clk;
  // SPI var. decl.
  wire miso, mosi, ss, sck;
  // SPI slave
  reg [`SEND_DATA_LENGTH - 1 : 0] slave_send_data = 12'hf55;
  wire [`RECV_DATA_LENGTH - 1 : 0] slave_recv_data;
  reg [`RECV_DATA_LENGTH - 1 : 0] slave_recv_buff = 0;
  reg [7:0] slave_read_val = 0;
  wire slave_recv_data_rdy;
  reg clk = 0;
  wire rst;
  spi_slave sl(
    miso, mosi, ss, sck, slave_send_data, slave_recv_data, slave_recv_data_rdy, __fpga_clk, rst
  assign __fpga_clk = CLK100MHZ;
  // slave_read_val is a buffer set by the SPI slave each time it finishes reading 8 + 4 bits
  // (the last 4 are dummy bits to provide more clock cycles, see below)
  assign LED[0] = slave_read_val[0];
  assign LED[1] = slave_read_val[1];
  assign LED[2] = slave_read_val[2];
  assign LED[3] = slave_read_val[3];
  assign LED[4] = slave_read_val[4];
  assign LED[5] = slave_read_val[5];
  assign LED[6] = slave_read_val[6];
  assign LED[7] = slave_read_val[7];
  // JA is the PMOD header 0
  assign JA[0] = mosi;
  assign JA[2] = ss;
  assign JA[3] = sck;
  assign JA[4] = rst;
  // Capture SPI rx buffers
  always @ (posedge slave_recv_data_rdy) begin
    slave_read_val <= slave_recv_data[7:0];
  end
endmodule
Edge detectors
module pos_edge_det ( input wire sig,
                      input wire clk,
                      output wire pe);
  reg   sig_dly;
  always @ (posedge clk) begin
    sig_dly <= sig;
  end
  assign pe = sig & ~sig_dly;
endmodule
module neg_edge_det ( input wire sig,
                      input wire clk,
                      output wire pe);
  reg   sig_dly;
    sig_dly <= sig;
  end
  assign pe = sig | ~sig_dly;
endmodule
SPI slave device
The SPI slave is supposed to read 8 bits + 4 dummy bits that are there just to provide the device enough clock cycles to finish all its work. I'm aware of this is no longer necessary given that it now receives the main FPGA clock, but I want to focus on the de-synchronization problem.
The SPI module (see bottom of the snippet below) instantiates both tx and rx, but tx can be ignored since I'm only testing the rx part for now.
module spi_slave
  #(parameter SEND_DATA_LEN = 12, parameter RECV_DATA_LEN = 8)(
  output wire miso,
  input wire mosi,
  input wire ss,
  input wire sck,
  input wire [SEND_DATA_LEN - 1 : 0] send_data,
  output wire [RECV_DATA_LEN - 1 : 0] recv_data,
  output wire recv_data_rdy,
  input wire clk,
  input wire rst
  wire psck;
  wire nsck;
  wire prst;
  pos_edge_det ped_psck(sck, clk, psck);
  neg_edge_det ned_psck(sck, clk, nsck);
  pos_edge_det ped_rst(rst, clk, prst);
  spi_tx #(.DATA_LENGTH(SEND_DATA_LEN)) tx(miso, ss, nsck, send_data, prst, clk);
  spi_rx #(.DATA_LENGTH(RECV_DATA_LEN)) rx(mosi, ss, psck,
                                           recv_data, recv_data_rdy, prst, clk);
endmodule
module spi_rx
  #(parameter  DATA_LENGTH = 8)(
  input wire rx,
  input wire ss,
  input wire sck,
  output reg [DATA_LENGTH - 1 : 0] data,
  output reg data_rdy,
  input wire prst,
  input wire clk
  localparam IDLE = 0, RECV = 1, DUMMY_BITS = 2;
  reg [DATA_LENGTH - 1 : 0] buff = 0;
  reg [3:0] idx = 0;
  reg [3:0] dummy_bits_cnt = 0;
  reg [4:0] timer = 0;
  reg [1:0] cs = IDLE;
  initial begin
    data <= 0;
    data_rdy <= 0;
  end
  always @ (posedge clk or posedge prst) begin
    if (prst) begin
      buff <= 0;
      idx <= 0;
      dummy_bits_cnt <= 0;
      timer <= 0;
      cs <= IDLE;
      data <= 0;
      data_rdy <= 0;
    end else if (sck) begin
      case (cs)
      IDLE: begin
        if (!ss) begin
          cs <= RECV;
          data_rdy <= 0;
          data <= 0;
          buff[idx] <= rx;
          idx <= idx + 1;
        end
      end
      RECV: begin
        idx <= idx + 1;
        if (idx >= DATA_LENGTH) begin
          data <= buff;
          buff <= 0;
          idx <= 0;
          cs <= DUMMY_BITS;
        end else begin
          buff[idx] <= rx;
        end
      end
      DUMMY_BITS: begin
        if (!data_rdy)
          data_rdy <= 1;
        dummy_bits_cnt <= dummy_bits_cnt + 1;
        if (dummy_bits_cnt == 2) begin
          cs <= IDLE;
        end
      end
      endcase
    end
  end
endmodule
  • \$\begingroup\$ I can come back later, if you don't get any help, please let me know. It seems like you are from C side. I like the __macro style in hdl, haven't thought to do that. Meantime, I noticed "always @ (posedge clk or posedge prst) begin". From my far distance memory, something did not like clocked by logic, and it may consume large amount of the resources. \$\endgroup\$
    – jay
    Nov 19, 2021 at 18:55
    \$\begingroup\$ So did you simulate this with any spi master before proceeding to on-board testing? \$\endgroup\$
    – Mitu Raj
    Nov 19, 2021 at 18:59
  • \$\begingroup\$ Yes, I have simulated it with a master implemented by me as well. Everything works, I can provide the GTKWave caputre. \$\endgroup\$
    – Martel
    Nov 19, 2021 at 19:00
  • \$\begingroup\$ If it works in simulation, could it be something as simple as your LEDs being active low (i.e. a 0 turns the LED on)? \$\endgroup\$ Nov 19, 2021 at 19:05
    \$\begingroup\$ I'm suspicious of your @(posedge slave_recv_data_rdy) block - usually edge sensitivity is done on a clock. You can use the clock edge, and if (slave_recv_data_rdy) begin.... \$\endgroup\$
    – awjlogan
    Nov 19, 2021 at 20:36
I suspect you are not capturing your SCLK signal correctly in the FPGA's CLK100MHZ domain. Compare your code to Tom's answer to your previous question. Notice that he says to use a synchroniser, which is (usually) two back to back D-flip flops. In your edge detectors, you only have a single DFF so your SPI SCLK signal might be metastable. Unless you are running clock domain crossing (CDC) aware simulation, this will appear to work as normal simulation has no concept of metastability.
You need a structure like this:
2 D Flip Flop Synchroniser
This can be expressed as:
module cell_sync (
    input  wire clk,
    input  wire rst,
    input  wire in_p,
    output wire out_p
reg in_meta_q;
reg in_sync_q;
always @(posedge clk or posedge rst) begin
    if (rst) begin
        in_meta_q <= 1'b0;
        in_sync_q <= 1'b0;
    end else begin
        in_meta_q <= in_p;
        in_sync_q <= in_meta;
    end
end
assign out_p = in_sync_q;
endmodule : cell_sync
Then feed the synchronised output to your positive edge detector.
    \$\begingroup\$ Yes, that was the problem, thanks. I use icarus verilog to run my simulations, and I haven't found any flag to make it CDC. What simulators have this capability? \$\endgroup\$
    – Martel
    Nov 22, 2021 at 10:51
    \$\begingroup\$ I don't think there's any free CDC verification tools. If you have access to paid, then QuestaCDC (Mentor), SpyGlass (Synopsys), and Conformal (Cadence) are the leading tools. If you don't, a simple hack is to set your simulation clocks to non-integer ratios and you might pick up some incorrect transmissions that you wouldn't see with integer ratios. Good resource: sunburst-design.com/papers/CummingsSNUG2008Boston_CDC.pdf \$\endgroup\$
    – awjlogan
    Nov 22, 2021 at 11:15
