The situation
I have a AD7689 ADC whose voltage input is 0 - 4.096 V. The max. voltage of the measured signal is around 10V, and it never goes below 0.5 V. I'm using a resistor divider, followed by a LMV324 in a voltage follower config to drive the ADC as shown below.
My Question:
In previous applications, I've simply put a 100k pull down at the input pin of the ADC, so when there's an open circuit the ADC will read 0V and this will trigger some routine in software.
Will R3 still work in the circuit below as the default value when an open circuit is detected, or should I put such pull down resistor before the resistor divider?
