I'm looking for a 4-pin version of this 5-pin cable connector. It is for the Bluetooth module on a LiFePo4 BMS. You can see both PCB connectors in the 3rd picture. 2.5 mm pitch.
Can anyone identify the specific connector name?
5 pin latch
Figure 1: 5-pin latching connector, end view
5 pin latch top
Figure 2: 5-pin latching connector, top view
4 pin board side
Figure 3: 4-pin and 5-pin PCB latching connectors
  • \$\begingroup\$ 2.5mm or 2.54mm? 2.5mm is an oddball pitch, 2.54mm (0.1'') is super-standard. Measure center-to-center between the outmost pins on the widest 6 pin connector, then divide by 6. \$\endgroup\$
    – Lundin
    Nov 23, 2021 at 11:40
My connector identification utility found these possible matches:
  • MANUF. - SERIES
  • JST - XA
  • Molex - Mini-Lock
Of those, the JST XA looks most likely.
    \$\begingroup\$ Thanks Davide. I should have included the word 'pitch' after 2.5 mm. Edited original post. I looked at just about every JST connector I could find. Will look at Molex now. \$\endgroup\$
    – Mark L
    Nov 21, 2021 at 2:18
  • \$\begingroup\$ That leaves 2: * MANUF. - SERIES * JST - XA * Molex - Mini-Lock \$\endgroup\$ Nov 21, 2021 at 15:47
    \$\begingroup\$ BTW: thanks for creating that website/tool. Amazing amount of information there! \$\endgroup\$
    – Mark L
    Nov 21, 2021 at 18:01
  • \$\begingroup\$ Thank you. It's a work in progress. \$\endgroup\$ Nov 21, 2021 at 18:02
I think this may be a "clone" of your connector. 2.50mm Pitch XHB crimp style connector.
Your images look more like the 2.0mm pitch version that I was looking for when I ran across your post. (mfg by Yeonho and TAIHUA)
2.0mm version image: A2005-PHB connector image
