I am building a DC energy generating device that at the moment generated DC power at 15K-50k Volts at 1 microampere.
I am considering using a high impedance ADC (1G ohm, 0.3V range, 2 nanoamperes current, 32 bits.)
When I plan out a voltage divider circuit to work with this ADC my voltage or current is always out of range.
I would ideally like to tune my circuit so current is between 0-0.3V and I have 2 nanoamperes for the ADC to sample. It also requires a very expensive 100G ohm or more resistor.
Is there a way (with op amps perhaps) to reduce the voltage but keep the current high and be more cost effective?
32 bits is far more precision than I need so even if the range becomes more like 0-0.003V that is acceptable.
