I'm a little confused, can someone explain to me why this circuit conducts?
I thought that the body diode of the PMOS was in reverse polarity and the source node of PMOS should be at 0V, but simulation shows the opposite.
This is a reverse polarity protection circuit and normally it would be supplied from the source node, but I want to know why in this configuration the circuit behaves like this.
The diode will be in reverse, but the FET is labeled wrong.
You are feeding the 10V to source and pulling the gate low, so FET is on.
  • \$\begingroup\$ OMG, i'm so blind, thx \$\endgroup\$
    – giusepe
    Nov 22, 2021 at 10:03
