I have very old computers; from time to time the RAM disconnects. I remove the DIMMs, clean the sockets using Isopropyl alcohol many times until it works again.
It will be fine for few weeks, but I can't use both DIMMs even when I tried 10 times; one will not work.
I expected mechanical failure of one tiny connector and repeated heat/cold of the main board, is there any solution except simply cleaning?
