In the IoT induced craze I'm doing some messy kind of interface bridge board. As in: USB, Bluetooth and various other serial things on a 60×60mm space.
At this moment I would have:
  • 25MHz for the MCU
  • Some frequency for the external UARTs (maybe the same 25MHz since they have prescalers before the BRG)
  • A Bluetooth module (luckily no external clocks for this!)
  • The internal 12MHz free generator + PLL for an FT232R (USB serial port)
  • A 12MHz crystal + PLL for an FT311D
All of these clock on the same board really worry me from an EMC standpoint. The only fact that the FT232R is free running at 1600ppm tolerance while the FT311D has a crystal on the same nominal frequency only promises beat frequencies in my experience (in the kHz range probably).
I was thinking to 'degrade' the MCU and UARTs to 24MHz, divide to 12MHz and external clock the USB circuitry. Since the board is small, the clocks are slow (for modern standards, anyway) and jitter is not really an issue (since almost of the parts will PLL the clock anyway) the idea was to:
  • Pick a cheap 24MHz HC oscillator
  • Divide and buffer with standard LVC (or better) logic
  • Appropriately distribute and couple the resulting clock lines to the relevant parts (for example the FT232R needs AC coupling for some reason while the FT311D needs a 1.8V clock)
The other way would be to use dedicated (and expensive) clock circuitry (like a PLL synth) still with the coupling issues to be taken care off.
Do you have experience with these situations? At the moment the choice is:
  • Everything with its own crystal/oscillator/whatever and hope for the best;
  • A cheap oscillator, discrete standard logic for division and distribution;
  • Dedicated clock generation circuitry.
Suggestions?
EDIT: aftermath having consulted the manufacturer (FTDI): the FT232R can use an external clock but it's not really recommended and nobody does that (!?!); the FT311D simply can't use an external clock and requires its own crystal. FUN
Pretty application specific, but as always it's a engineering trade off (cost, area, complexity). For your particular application, personally, I would go for cheap oscillator and divide down:
  • It doesn't sound like you have anything which relies on an extremely accurate clock, except perhaps the USB receiver. If you pick a nice multiple of that clock, you should be fine. The MCU can run at "any" frequency, and if your UART has prescaling you can use that.
  • You are space constrained, and crystals tend to be fairly bulky with awkward routing.
  • Your clocks are similar speeds so, as your mention, you might get some beats. If you have a single clock source, you mitigate this issue.
    \$\begingroup\$ The 311D chip only asks for a 0.5% crystal, dividing down gives a pretty good 50% duty cycle and it regenerates it to 48MHz internally anyway so jitter shouldn't be an issue. For the rest more or less the same conclusions I had \$\endgroup\$ Nov 25, 2021 at 6:49
  • \$\begingroup\$ @LorenzoMarcantonio - yes, I usually go for distribution once over 2 distinct clocks if possible. Your edit to the original question is a problem though! \$\endgroup\$
    – awjlogan
    Nov 25, 2021 at 9:37
