-2
I have a computer I'm using as a server, I would want it to turn on on its own when power is cut off, and I figured the easiest way is to connect a micro, maybe an attiny85, that will short the power button pins with a transistor when it is reset (I've checked and the BIOS does not support automatic boot on power on).
However, for this I would need to access the +5VSB rail, is there a standard way to get it from an ATX motherboard? I was thinking about printing a PCB that plugs in one of the PCI-e x1 slots, but it looks like it doesn't have +5VSB, not even any +5V
  • \$\begingroup\$ Tap splice into the main ATX power connector? \$\endgroup\$
    – vir
    Nov 24, 2021 at 19:09
  • \$\begingroup\$ Why do you need 5V specifically? PCIe has 3.3V standby. It might be possible to configure one or several USB ports to run from 5V standby supply. How about a relay to push the button until 5V or 12V supply turns on? \$\endgroup\$
    – Justme
    Nov 24, 2021 at 19:28
  • \$\begingroup\$ @Justme I've never heard of 3v3 standby, is it step down from +5vsb? If not it will not be available when the power is off \$\endgroup\$
    – Mauro F.
    Nov 24, 2021 at 19:35
  • \$\begingroup\$ @MauroF. It's optional, but if it's implemented, where else would it come from except from +5VSB? \$\endgroup\$
    – Justme
    Nov 24, 2021 at 20:16
4 Answers 4
Apparently +5VSB is available from PS/2 mouse and keybaord ports. This is not true for every computer I've tested, but for some it is, for the one I'm working on luckily it is, so I can get it from this port.
+5VSB is pin #9 on the ATX connector. You can run a jumper from the connector (or splice a connector into the wiring harness of the power supply). The purple wire.
USB headers are the standard ways, and USB supplies are typically fairly fault tolerant. You don't want to ruin your motherboard with a short, do you.
Solution: don't do anything special. The ATX power supply standard is specified exactly for that, and supplies a 5V standby voltage to keep an onboard controller happy, which typically can turn on a computer on a specific time, or when a specific network packet is encountered. Or, after a power failure! There's even a specific setting for that in all UEFI setup UIs I've seen in a while.
You don't need any additional hardware for this. This is standard functionality.
    \$\begingroup\$ Please at least read the question before replying. I specifically said that my bios does not support this option (not every motherboard does). Also can you source that USB uses +5VSB? My computer's usb ports are NOT powered when the computer is off but still connected to the power \$\endgroup\$
    – Mauro F.
    Nov 24, 2021 at 19:25
  • \$\begingroup\$ hm, I have one of the on-board USB pin headers being "off-enabled" (marketing-wise, to allow for charging of phones etc) \$\endgroup\$ Nov 24, 2021 at 19:26
    \$\begingroup\$ Re: your bios doesn't have it: chances are, your bios setup frontend doesn't show it, but it's there! (would be a strange omission from firmware) \$\endgroup\$ Nov 24, 2021 at 19:37
  • \$\begingroup\$ those USB charging port are unfortunately not available on my botherboard (which is almost 8 years old, and they were no as common), also I've seen it more often on laptops than desktops. And regarding the UEFI settings, well it's not I can really do anything about it if they don't allow me to set this option, I've looked in every advanced option and I couldn't find anything. However, I've found a solution for this paritcular problem \$\endgroup\$
    – Mauro F.
    Nov 24, 2021 at 19:57
The easiest thing way to get +5VSB is to splice it out of the ATX power connector. While it might be available on the motherboard in a few places, it would be easier to cut or use a splice connector like this one
