-2
Can someone help me find the voltages dropped across the components in this circuit by using nodal analysis?
I got the first equation (on the top left of the circuit) to be 7V1 - 2V2 = 40, but I don't know how to get the second one.
New contributor
Dylan Oneill is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
  • \$\begingroup\$ Might be easier if you convert that 4A and 2Ohm resistor into a thevenin source \$\endgroup\$ yesterday
  • \$\begingroup\$ ok, im not quite sure how i do that, do i basically just simplify the circuit to get one component for the resistors etc? \$\endgroup\$ yesterday
    \$\begingroup\$ It’s best if you share the problem statement of the assignment and the work you have up to the point where you got stuck \$\endgroup\$ yesterday
  • \$\begingroup\$ the aim of the question is to get the voltages dropped across the components by using nodal analysis \$\endgroup\$ yesterday
  • \$\begingroup\$ i chose V1 to be in the top left of the circuit and the equation i got for that was 7v1-2v2=40 \$\endgroup\$ yesterday
Dylan Oneill is a new contributor. Be nice, and check out our Code of Conduct.
