This is my first time diving into DC/DC converters, so I'm learning a lot of new information and am aware that I may miss some important details. I'm hoping that others with more experience could point out and educate me about those, why they are crucial, and what they cause.
A little bit about the circuit
My input voltage is around 5V (I put 4.5 to 5.5V in the TI designer), with an output of a little over 3.3V. The expected load of the powered circuit is around 800mA, worst-case about 1.4A for a few minutes. For this purpose, I chose TI's LM2831XMF/NOPB (mostly because it was one of the only available 1.5A DC/DC converters I could find in stock near where I live due to chip shortage). I changed some of the components from the original "compact" design provided by TI's generator, like the inductor (IHLP1212BZER3R3M11) and the "drain" diode (SL04-HE3-08), which should be decent replacements for the suggested parts.
The schematic
This is the schematic I came up with at the end:
The PCB
The board I use has 4 layers. The red layer is the top layer, lower I have a ground layer followed by a VCC layer and the bottom layer. I try to provide a good ground for the output capacitor, diode and input capacitor (like suggested in the switching chip datasheet). I also put big pours as traces to reduce resistance between parts. Furthermore, I tried to reduce both fill and drain loops as much as possible, so this is the layout I came up with at the end:
Without copper pour for better visibility:
My existing concerns
What I'm worried about the most here is the feedback line, which I routed not that far from the inductor and could potentially cause output ripple. Would it be better to route it around the other side (to avoid the inductor more)? Doing that, I'm worried I'll make it into an even bigger antenna and worsen the situation. Do you perhaps have any suggestions on how to fix/deal with such an issue, or is it a non-issue as-is?
The solution:
This is the final design (imgur.com) I'll use in production. I'll also update with some ripple data once I get the circuit and assemble the regulator.
Update: this design produces under somewhere around 5 mV of ripple, which should be good enough for most designs.
