Most sources on the web say that 1.3 eV or 1.4 eV is 'ideal' for most solar cells...
What happens to lower-gap, gapless or overlap materials (conductors)? Are they ionized, rather than sending their electrons neatly into the conduction band?
P.S.: May I also ask if there are advantages, disadvantages to using 'direct' bandgap semiconductors vs. indirect band gap ones?
  • \$\begingroup\$ You only get about 0.5V (maybe 0.55V open circuit) from a Si cell. This is the one place where you really want a higher forward voltage in a diode. \$\endgroup\$
    – user16324
    Commented Nov 27, 2021 at 14:43
See these lecture slides (42 pages) Light Absorption and Thermalization:
http://oasis.mechse.illinois.edu/me432/ME432_L12_Sept21.pdf
Page 15 Thermal Efficiency vs Band Gap
For small band gaps, efficiency is limited by thermalization losses
For large band gaps, efficiency is limited by losses due to non- absorption of the solar spectrum
The tradeoff between thermalization and non-absorption losses results in the optimal band gap of a semiconductor of approximately 1.2 eV, and a maximum theoretical efficiency of close to 30%.
Page 36:
Light absorption in a direct semiconductor requires only photons
Light absorption in an indirect semiconductor requires a photon and a phonon, and is statistically less likely to occur.
Page 38:
Solar cells made from indirect semiconductors need to be thicker because we need to provide more opportunities for the transition to take place.
Page 39:
Absorption in indirect semiconductors is temperature-dependent, because phonons are needed and phonon population depends on temperature.
The direct materials may seem to have an advantage, however, the economics and design tradeoff in a given application are not discussed in the reference.
