I need to make a circuit with an opamp and passive components that has those constraints :
- When it receives a pulse on one input, its output should be high.
- After a predefined duration T, it should switch back to low state
- If a second pulse is received while the output is still high, the duration before the switch should be reset back to T
In a nutshell, it should behave kind of like a watchdog timer but made with passives and an opamp, as I can't use an IC with this precise function because of contraints on the components I can use.
I have already tried this:
When it receives a pulse on the positive input, the output will be high while the voltage on the negative input is lower than half (R89 / (R88 + R89)) the output voltage. The main problem is that the circuit is not really reset when another pulse occurs, which means the output will be switched low regularly, even if the timer should be reset:
Do you have any idea either how to improve the circuit, or of another one to achieve the same goal?
