I require a solid state relay to be able to switch high side, but also has low on-resistance.
G3VM has low on-resistance but it's application diagram shows exclusively low-side switch.
Question:
  1. what is this configuration of FETs called ?
  2. Since it's isolated, why it cannot be used as high side switches ?
    \$\begingroup\$ Nothing that says they cant be used for high side other than your interpretation. They are simply back to back mosfets. \$\endgroup\$
    – Kartman
    Dec 1, 2021 at 0:27
    \$\begingroup\$ connection A shows a high side switch 50% of the time \$\endgroup\$
    – jsotola
    Dec 1, 2021 at 0:29
Connection C is the high side switch to the load, if DC negative terminal = pins 6,7 as shown. Gnd is where you decide is 0V.
The Nch FETs are just ganged in parallel in "C" as a common-source mode switch (common to input and output) and switched drain.
