For the 1st question, is this a Sallen-Key filter? What criteria must a circuit possess in order for it to classified as a Sallen-Key filter? I searched the internet but found no clear answer.
For finding the frequency: my attempt, see below, defines node voltages Va and Vb and uses nodal analysis to find the transfer function, treating vo = vb since the opamp will regulate the voltage at the inverting input the same as the non-inverting input.
After finding the transfer function, I differentiated with respect to f to find the value in terms of R and C.
$$\frac{v_i-v_a}{R}=\frac{v_a-v_b}{R}+\frac{v_a-v_b}{\frac{1}{jwc}}$$ $$\frac{v_a-v_b}{\frac{1}{jwc}}=\frac{v_b}{R||\frac{1}{jwc}}$$
After substituting Va in terms of Vb,A = Vb/Vi, I got the equation below:
$$gain=\frac{jwc}{3+w^2Rc-j(6wRc+wc)}$$
This is as far as I got, I am stuck on how I can get the above answer. Is the nodal analysis equation I derived correct?
