I'm trying to add this component to my design in Altium but I don't understand this kind of "holes" (I suppose it can't be drilled properly.) I can't find any tool in Altium to design this hole. Is there a way to do it?
I have tried to do 2 holes and put on one over the other but on 3D view it can be seen this (i'm trying to d this from footprint editor):
    \$\begingroup\$ These would be slots I believe you're asking about. You can use non-plated pads with x/y different values, and choose "slot" for the pad-stack. Then you might overlap two slots to get what you require, in this case a type of L-slot. The exterior of the periphery isn't clear from your drawing if they are counter-bored or otherwise if it is copper-plated etc. \$\endgroup\$
    – citizen
    Dec 2, 2021 at 15:19
    \$\begingroup\$ As an FYI, these plated slots are actually drilled- using a series of overlapping holes to get a fairly smooth internal edge. \$\endgroup\$ Dec 2, 2021 at 15:22
    \$\begingroup\$ The 3D view doesn't show reality. What you're seeing in that view doesn't indicate there will be any problem with the finished product. \$\endgroup\$
    – The Photon
    Dec 2, 2021 at 17:28
Two possible ways:
  1. Combine two slot holes:
  1. Draw both hole and annular ring with lines, convert it to the board cutout (Tools - Convert - Create board cutout) and copper region (Tools - Convert - Create region)
In both cases, you'll need to override DRC rules. The situation will be easier for a first case because it's just one rule - hole-to-hole clearance.
Also, it'll be a good idea to warn your PCB house about this stuff because it doesn't quite fit into "standard" PCB features. If the PCB house won't know what you want to achieve - there is a possibility to receive manufactured PCB without slot plating.
  • \$\begingroup\$ First method might be more preferable because cut-outs don't appear in the gerber files. They are helpful especially for 3D. \$\endgroup\$ Dec 2, 2021 at 16:00
  • \$\begingroup\$ Yes, if you considered 3D rendering your PCB. But from a manufacturing point of view, I’d like to suggest that interleaved slots are a more “classical” approach \$\endgroup\$
    – Looongcat
    Dec 3, 2021 at 19:04
