So I am doing a Monte Carlo Simulation on LTSpice. Then I want to export my data and manipulate it in MATLAB.
Here is a working example file, just with 2 decades each one with 11 points and 6 iterations of Monte Carlo:
Freq.   V(vout)
Step Information: X=0  (Run: 1/6)
1.00000000000000e-002   (-6.26777881841443e+000dB,-2.45632080921360e+001°)
1.25892541179417e-002   (-6.36861181114449e+000dB,-3.06433832660851e+001°)
1.58489319246111e-002   (-6.50874601655850e+000dB,-3.80698128918313e+001°)
1.99526231496888e-002   (-6.68840252431672e+000dB,-4.70502691728284e+001°)
2.51188643150958e-002   (-6.88767600648017e+000dB,-5.78295465358373e+001°)
3.16227766016838e-002   (-7.04662306199209e+000dB,-7.08121145050537e+001°)
3.98107170553497e-002   (-7.04613385608013e+000dB,-8.69037556678446e+001°)
5.01187233627273e-002   (-6.73302774870351e+000dB,-1.08291925528466e+002°)
6.30957344480194e-002   (-6.17898060206205e+000dB,-1.39490624870074e+002°)
7.94328234724282e-002   (-6.29156027893901e+000dB,1.76371893719709e+002°)
1.00000000000000e-001   (-7.00343610611535e+000dB,1.25917428931445e+002°)
1.25892541179417e-001   (-6.07744581972252e+000dB,4.88363107428150e+001°)
1.58489319246111e-001   (-6.92190787935448e+000dB,-1.05087106512531e+002°)
1.99526231496888e-001   (-3.64476579715909e+001dB,1.50248213268233e+002°)
2.51188643150958e-001   (-5.65563441261771e+001dB,1.30679615367055e+002°)
3.16227766016838e-001   (-7.35748460393752e+001dB,1.19998987277993e+002°)
3.98107170553498e-001   (-8.92621053142513e+001dB,1.12887963014667e+002°)
5.01187233627273e-001   (-1.04257065089212e+002dB,1.07760106447624e+002°)
6.30957344480194e-001   (-1.18860319936777e+002dB,1.03910331684806e+002°)
7.94328234724282e-001   (-1.33231869456083e+002dB,1.00954550855709e+002°)
1.00000000000000e+000   (-1.47462843245236e+002dB,9.86551571694855e+001°)
Step Information: X=1  (Run: 2/6)
1.00000000000000e-002   (-6.16672256403144e+000dB,-2.44850335449979e+001°)
1.25892541179417e-002   (-6.26639121158446e+000dB,-3.05477574094463e+001°)
1.58489319246111e-002   (-6.40485695767013e+000dB,-3.79544592941995e+001°)
1.99526231496888e-002   (-6.58222673567182e+000dB,-4.69137543618026e+001°)
2.51188643150958e-002   (-6.77853960525347e+000dB,-5.76720745778276e+001°)
3.16227766016838e-002   (-6.93392757217094e+000dB,-7.06368382452438e+001°)
3.98107170553497e-002   (-6.92972272669119e+000dB,-8.67198835897928e+001°)
5.01187233627273e-002   (-6.61488302611489e+000dB,-1.08121876478984e+002°)
6.30957344480194e-002   (-6.07070535374054e+000dB,-1.39362050183132e+002°)
7.94328234724282e-002   (-6.21965984211102e+000dB,1.76590682774648e+002°)
1.00000000000000e-001   (-6.95327975730355e+000dB,1.26605975615689e+002°)
1.25892541179417e-001   (-5.98464834532776e+000dB,4.97190587873480e+001°)
1.58489319246111e-001   (-6.40417682367860e+000dB,-9.75145351869804e+001°)
1.99526231496888e-001   (-3.60323515588510e+001dB,1.49599381516468e+002°)
2.51188643150958e-001   (-5.62806798193614e+001dB,1.30188107624632e+002°)
3.16227766016838e-001   (-7.33429304420458e+001dB,1.19642264129678e+002°)
3.98107170553498e-001   (-8.90496342710569e+001dB,1.12621087528093e+002°)
5.01187233627273e-001   (-1.04054663427162e+002dB,1.07555972526800e+002°)
6.30957344480194e-001   (-1.18663568970525e+002dB,1.03751971633780e+002°)
7.94328234724282e-001   (-1.33038438305737e+002dB,1.00830612529090e+002°)
1.00000000000000e+000   (-1.47271416461901e+002dB,9.85576222906644e+001°)
Step Information: X=2  (Run: 3/6)
1.00000000000000e-002   (-6.21225990393714e+000dB,-2.42398271464396e+001°)
1.25892541179417e-002   (-6.30909308389625e+000dB,-3.02474562172609e+001°)
1.58489319246111e-002   (-6.44368675411592e+000dB,-3.75911929919443e+001°)
1.99526231496888e-002   (-6.61617014498940e+000dB,-4.64809809162114e+001°)
2.51188643150958e-002   (-6.80702103232767e+000dB,-5.71648578399885e+001°)
3.16227766016838e-002   (-6.95744340949862e+000dB,-7.00503088335492e+001°)
3.98107170553497e-002   (-6.95058694718676e+000dB,-8.60451477040284e+001°)
5.01187233627273e-002   (-6.63826350750918e+000dB,-1.07340680147192e+002°)
6.30957344480194e-002   (-6.10854527731718e+000dB,-1.38439087101438e+002°)
7.94328234724282e-002   (-6.30362830475549e+000dB,1.77802087261242e+002°)
1.00000000000000e-001   (-7.12172801096167e+000dB,1.28771964802357e+002°)
1.25892541179417e-001   (-6.03607855680839e+000dB,5.40055044059610e+001°)
1.58489319246111e-001   (-6.09076329776158e+000dB,-7.96416809130710e+001°)
1.99526231496888e-001   (-3.50723893849773e+001dB,1.49324548669222e+002°)
2.51188643150958e-001   (-5.56565653180954e+001dB,1.29763151240751e+002°)
3.16227766016838e-001   (-7.28297203350366e+001dB,1.19299898524730e+002°)
3.98107170553498e-001   (-8.85876592266688e+001dB,1.12354271502988e+002°)
5.01187233627273e-001   (-1.03619895627022e+002dB,1.07347693711844e+002°)
6.30957344480194e-001   (-1.18244315768821e+002dB,1.03588572559094e+002°)
7.94328234724282e-001   (-1.32628393065329e+002dB,1.00701890827225e+002°)
1.00000000000000e+000   (-1.46866966442567e+002dB,9.84559235597901e+001°)
Step Information: X=3  (Run: 4/6)
1.00000000000000e-002   (-6.22331279803977e+000dB,-2.46332673587796e+001°)
1.25892541179417e-002   (-6.32504917213284e+000dB,-3.07272672560921e+001°)
1.58489319246111e-002   (-6.46623144544338e+000dB,-3.81680557698355e+001°)
1.99526231496888e-002   (-6.64677864154134e+000dB,-4.71624573226846e+001°)
2.51188643150958e-002   (-6.84606579338628e+000dB,-5.79553475142998e+001°)
3.16227766016838e-002   (-7.00283755937839e+000dB,-7.09556477273628e+001°)
3.98107170553497e-002   (-6.99627249573579e+000dB,-8.70859007405126e+001°)
5.01187233627273e-002   (-6.67343602866177e+000dB,-1.08579125550146e+002°)
6.30957344480194e-002   (-6.12030688950781e+000dB,-1.40015647535145e+002°)
7.94328234724282e-002   (-6.27478190951681e+000dB,1.75681713302692e+002°)
1.00000000000000e-001   (-6.99206525364281e+000dB,1.25430995493748e+002°)
1.25892541179417e-001   (-6.03691617350726e+000dB,4.75748098362317e+001°)
1.58489319246111e-001   (-6.78167767121785e+000dB,-1.05705064001918e+002°)
1.99526231496888e-001   (-3.66017286534973e+001dB,1.49104719709746e+002°)
2.51188643150958e-001   (-5.67225468275595e+001dB,1.29982261243041e+002°)
3.16227766016838e-001   (-7.37401305848446e+001dB,1.19514081606539e+002°)
3.98107170553498e-001   (-8.94256387901318e+001dB,1.12530467253416e+002°)
5.01187233627273e-001   (-1.04419241358117e+002dB,1.07488355447641e+002°)
6.30957344480194e-001   (-1.19021571859160e+002dB,1.03700150338241e+002°)
7.94328234724282e-001   (-1.33392517159571e+002dB,1.00790315794714e+002°)
1.00000000000000e+000   (-1.47623102632076e+002dB,9.85260246778205e+001°)
Step Information: X=4  (Run: 5/6)
1.00000000000000e-002   (-6.23268747704643e+000dB,-2.50410800230128e+001°)
1.25892541179417e-002   (-6.33917575843080e+000dB,-3.12217854974529e+001°)
1.58489319246111e-002   (-6.48629042886293e+000dB,-3.87581607866792e+001°)
1.99526231496888e-002   (-6.67304499854865e+000dB,-4.78538422903985e+001°)
2.51188643150958e-002   (-6.87639806629557e+000dB,-5.87536116429439e+001°)
3.16227766016838e-002   (-7.03051544993454e+000dB,-7.18804940213071e+001°)
3.98107170553497e-002   (-7.00828150775649e+000dB,-8.82104246417903e+001°)
5.01187233627273e-002   (-6.65530648891537e+000dB,-1.10119730420866e+002°)
6.30957344480194e-002   (-6.09469920219503e+000dB,-1.42405205514390e+002°)
7.94328234724282e-002   (-6.34016880658946e+000dB,1.72505719420889e+002°)
1.00000000000000e-001   (-7.04017166605841e+000dB,1.21990674426408e+002°)
1.25892541179417e-001   (-6.07437235545994e+000dB,4.12337724162087e+001°)
1.58489319246111e-001   (-8.18869568325135e+000dB,-1.25105992577795e+002°)
1.99526231496888e-001   (-3.80083248976535e+001dB,1.47144346294457e+002°)
2.51188643150958e-001   (-5.78497981809793e+001dB,1.28956714532505e+002°)
3.16227766016838e-001   (-7.47637582348090e+001dB,1.18825272338581e+002°)
3.98107170553498e-001   (-9.03986136722447e+001dB,1.12028380207313e+002°)
5.01187233627273e-001   (-1.05364437014045e+002dB,1.07108394410606e+002°)
6.30957344480194e-001   (-1.19950616999652e+002dB,1.03406857883888e+002°)
7.94328234724282e-001   (-1.34311862227457e+002dB,1.00561359030665e+002°)
1.00000000000000e+000   (-1.48536509737044e+002dB,9.83460945944903e+001°)
Step Information: X=5  (Run: 6/6)
1.00000000000000e-002   (-6.25082744156451e+000dB,-2.47181947915387e+001°)
1.25892541179417e-002   (-6.35355099949484e+000dB,-3.08297344200067e+001°)
1.58489319246111e-002   (-6.49590256038996e+000dB,-3.82894691652311e+001°)
1.99526231496888e-002   (-6.67751099794831e+000dB,-4.73034739546178e+001°)
2.51188643150958e-002   (-6.87704700139995e+000dB,-5.81169846727973e+001°)
3.16227766016838e-002   (-7.03196827194024e+000dB,-7.11437980905331e+001°)
3.98107170553497e-002   (-7.01979302428447e+000dB,-8.73238848974908e+001°)
5.01187233627273e-002   (-6.68796414576871e+000dB,-1.08936886014197e+002°)
6.30957344480194e-002   (-6.13713289323238e+000dB,-1.40629994073302e+002°)
7.94328234724282e-002   (-6.33523944865220e+000dB,1.74880767731570e+002°)
1.00000000000000e-001   (-7.06204694631925e+000dB,1.24795188737801e+002°)
1.25892541179417e-001   (-6.07176510225266e+000dB,4.62141099523223e+001°)
1.58489319246111e-001   (-6.94683355469541e+000dB,-1.07596087699931e+002°)
1.99526231496888e-001   (-3.68700051939526e+001dB,1.48337323013288e+002°)
2.51188643150958e-001   (-5.69761930020967e+001dB,1.29501884676301e+002°)
3.16227766016838e-001   (-7.39858496501359e+001dB,1.19174614947729e+002°)
3.98107170553498e-001   (-8.96667862090866e+001dB,1.12277917628911e+002°)
5.01187233627273e-001   (-1.04657656100839e+002dB,1.07295362073189e+002°)
6.30957344480194e-001   (-1.19258318601153e+002dB,1.03550408363673e+002°)
7.94328234724282e-001   (-1.33628232853353e+002dB,1.00673080554496e+002°)
1.00000000000000e+000   (-1.47858176057854e+002dB,9.84337357907819e+001°)
So I already have a code that works with in case of a plot with just 1 iteration (it doesn't have the "Step Information: X=0 (Run: 1/6)" line . I've adapted this from another code I've seen.
clc;
close all;
clear all;
filename = 'FrequencyResponse.txt';
filetoread = fopen(filename, 'rt');
Dummy= textscan(filetoread, 'Freq.  V(vout)', 'CollectOutput', 1);
DataScanned = textscan(filetoread, '%f(%fdB,%f°)', 'CollectOutput',1);
fclose(filetoread);
D = cell2mat(DataScanned);
D(:,1)=D(:,1)*2*pi;
figure
subplot(2,1,1)
semilogx(D(:,1), D(:,2))
title('Amplitude (dB)')
grid
subplot(2,1,2)
semilogx(D(:,1), D(:,3))
title('Phase (°)')
grid
xlabel('Frequency')
So yeah this code works for just a normal simulation. Now for Monte Carlo there are a lot of challenges that I am facing. For instance:
1 - How should I read the "Step Information yada yada" and then read all the values and then stop at the next step information.
2 - How to read the number of iterations?
3 - How should I store the info of each interation? I'm thinking of a matrix, each column for each Monte Carlo iteration (frequency, voltage magnitude, voltage phase). But I already have a 3 column matrix...
Some help would be appreciated. I have little experience with MATLAB and I always struggled with reading files in C. So this is really confusing for me.
    \$\begingroup\$ I don't know anything about MATLAB. Never used it. (Money I won't shell out.) But it basically looked to me like you are stepping through a PARAM variable X from 0 to some limit and using that to modify things, generating a Bode plot each time. I don't know what you want to do in MATLAB, exactly. But I think you should work out exactly what you intend on doing with each Bode plot vector (each value is a 2-vector of magnitude and phase) and then read things up and do it. This should be something you can work out on paper, before coding, pretty easily. \$\endgroup\$
    – jonk
    Commented Dec 2, 2021 at 21:25
Something along the lines of this:
fn = "test_dat.txt";   % Filename variable - no trailing carriage return
S = readlines(fn); % read all lines into an array
STEP=0; % initialise counter
results = struct.empty; % initialise result structure
rx = '[+-.e0-9]*' % create regex pattern to match exponent numbers
for i=2:length(S) % loop over every line BUT skip the 1st
    if startsWith(S(i),'Step') % check if the line starts with the word "step", if so use this as a marker for a new step group
        STEP = STEP+1; % increment the STEP counter
        results(STEP).data = [0 0 0]; % seed a new results array
    else
        num = str2double(regexp(S(i),rx,'match')) % match the three exponential numbers in a line based upon regex pattern
        results(STEP).data = [results(STEP).data ; num(1) num(2) num(3)]; % create an row and append to the results table associated with this STEP
    end
end
figure;  % create a figure
subplot(2,1,1); % select 1st subplot
ylabel('Amplitude (dB)'); % set y label
xlabel('Frequency'); % set xlabel
set(gca, 'XScale', 'log'); % change xaxis to log
hold; % hold plot to permit multiple plots in one axis
grid; % turn on grid
subplot(2,1,2) % same steps for 2nd subplot
ylabel('Phase (°)')
xlabel('Frequency')
hold;
grid;
for i = 1:numel(results) % start looping over all entries in the results struct
    subplot(2,1,1) % select upper subplot
    plot(results(i).data(:,1)*2*pi, results(i).data(:,2)); % plot freq (1st column) and mag (2nd column)
    subplot(2,1,2) % select lower subplot
    plot(results(i).data(:,1)*2*pi, results(i).data(:,3)); % plot freq (1st column) and angle (3rd)
end
  • \$\begingroup\$ Hi Jon! Thank you for your answer. I've tried to run your code (changing the name to the one of my file of course) but get the following error: Index exceeds the number of array elements (0). Error in Graph_Script (line 17) results(STEP).data = [results(STEP).data ; num(1) num(2) num(3)]; Any idea why? Also I don't quite understand what you are doing with the rx line. Frankly I am having a lot of trouble understanding the meaning of everything, as I said I'm at a very beginning level in MATLAB. But thank you for your help! \$\endgroup\$ Commented Dec 2, 2021 at 23:40
  • \$\begingroup\$ what it will be is there is a blank line at the end of the file - I was too lazy to put a check in so if you ensure there is no trailing carriage return that should fix it. The rx is setting up a regex pattern to basically extract part of a line that contain those characters. \$\endgroup\$
    – user16222
    Commented Dec 2, 2021 at 23:45
  • \$\begingroup\$ Oh ok! Since the line is always present, I will just go until length(S)-1. I will try and give feedback, thank you very much for your help! \$\endgroup\$ Commented Dec 2, 2021 at 23:52
    \$\begingroup\$ or something like: if length(num) != 3 continue else results(STEP).data = .... \$\endgroup\$
    – user16222
  • \$\begingroup\$ Ok, thank you and thank you for also commenting the code, I will check it again tomorrow and if any new questions arise I'll comment here again. Thank you for your help, really! \$\endgroup\$ Commented Dec 3, 2021 at 0:02
