Well, the current through the inductor can be found using the current divider formula:
$$\text{i}_\text{L}\left(t\right)=\mathscr{L}_\text{s}^{-1}\left[\frac{\frac{1}{\text{sC}}}{\frac{1}{\text{sC}}+\text{sL}}\cdot\text{I}_\text{i}\left(\text{s}\right)\right]_{\left(t\right)}\tag1$$
Where \$\mathscr{L}_\text{s}^{-1}\left[\cdot\right]_{\left(t\right)}\$ is the inverse Laplace transform.
And it is not hard to see that:
$$\text{I}_\text{i}\left(\text{s}\right)=\frac{\text{V}_\text{i}\left(\text{s}\right)}{\text{R}_1+\text{R}_2+\left(\frac{1}{\text{sC}}\space\text{||}\space\text{sL}\right)}\tag2$$
Where \$\text{V}_\text{i}\left(\text{s}\right)=\frac{\hat{\text{u}}}{\text{s}}\$.
So, we get:
$$\text{i}_\text{L}\left(t\right)=\mathscr{L}_\text{s}^{-1}\left[\frac{\frac{1}{\text{sC}}}{\frac{1}{\text{sC}}+\text{sL}}\cdot\frac{\hat{\text{u}}}{\text{s}}\cdot\frac{1}{\text{R}_1+\text{R}_2+\left(\frac{1}{\text{sC}}\space\text{||}\space\text{sL}\right)}\right]_{\left(t\right)}=$$
$$\mathscr{L}_\text{s}^{-1}\left[\frac{\hat{\text{u}}}{\text{s}}\cdot\frac{1}{\text{CL}\left(\text{R}_1+\text{R}_2\right)\text{s}^2+\text{Ls}+\text{R}_1+\text{R}_2}\right]_{\left(t\right)}\tag3$$
Using your values, you will (must) find:
$$\text{i}_\text{L}\left(t\right)=\frac{2}{7}-\frac{2\exp\left(-\frac{t}{7}\right)}{679}\cdot\left(\sqrt{97} \sin \left(\frac{\sqrt{97} t}{7}\right)+97 \cos \left(\frac{\sqrt{97} t}{7}\right)\right)\tag4$$
