I'm trying to understand how an electrical load affects a circuit.
Let's say, for example, I have a setup that is on a 120 V, 15 A circuit:
- 120 V x 15 A = 1,800 W max
- if we have a continuous load (3+ hours), then we should aim for 80% amperage; so 15 A becomes 12 A and 120 V x 12 A = 1,440 W max
- if we maintain a continuous load of less than 1,440 W, there is nothing to worry about
- if we ever reach 1,801 W, the circuit breaker turns off immediately to prevent any damage to the circuit
My question is: If we have a system running continuously at somewhere in between (let's say 1,600 W), what happens?
- Does it do long-term damage to either the circuit or the electrical device(s)?
- Does it do short-term damage to either the circuit or the electrical device(s)?
- Does it make no difference at all until a new load is introduced that pushes it over 1,800 W?
And does it make a difference whether the voltage or amperage changes?
- If we have 240 V x 20 A = 4,800 W max and 240 V x 16 A = 3,840 W (continuous), and we run the system somewhere in between (like 4,200 W continuous), would the same concept apply (ie, same level of damage/non-damage) or would it be less or more damaging due to more power being involved?
Edit: Thank you for all your answers. I regret being able to only vote 1 answer as being correct. :[
