How can I convert a pulse signal into a square wave.
I have a pulse signal created using a Function Signal Generator, ZK-PP2K Pulse Frequency Generator 8A Driver Module LCD Pulse Frequency Cycle Module 1Hz-150KHz Motor Controller LCD Display https://www.amazon.com/Function-Generator-Frequency-1Hz-150KHz-Controller/dp/B08HV2FPJR
Specifications:
1>.Product name: ZK-PP2K PWM Signal Generator
3>.Work voltage:DC 3.3V-30V
4>.Frequency range:1Hz~150KHz
5>.Frequency accuracy:2%
6>.Duty cycle range:0.00%-100%
7>.Output Current:8A(Max)
8>.Number of pulses:1~9999 or Infinite
9>.Delay time:0.000s~9999s
10>.Pulse width:0.000s~9999s
I watched a video that uses simulink to create a model that does this. https://youtu.be/m6aw6HcIbPc
How can I convert this simulink example into a "workable" circuit. My thoughts were to use a combination of an op-amp and bridge wave rectifiers but I think I'm over thinking it since I already have the pulse generated. Any thoughts?
