Can a diode be made by connecting, in series, separate n and p-type semiconductors?
Assume that all ends are attached to Ohmic contacts. I am hoping that this will prevent any discontinuities in the potential.
I have seen a similar question on the Physics Stack Exchange, but the question is too old to make comments (https://physics.stackexchange.com/questions/72432/would-connecting-p-type-and-n-type-semiconductors-work-as-a-diode). But in that question, they didn't talk about Ohmic contacts.
Hypothetical Diode
    \$\begingroup\$ No, you need P and N doped stuff to physically touch. There forms a barrier. \$\endgroup\$
    – Ilya
    Dec 6, 2021 at 14:26
  • \$\begingroup\$ @Ilya What difference does it make if ohmic contacts are present. The potential at the end of the p-side will continue at the start of the n-side right? \$\endgroup\$ Dec 6, 2021 at 15:49
  • \$\begingroup\$ Where P and N regions touch, there appears a "neutral" zone, small layer of "undoped" (electrically-neutral more like) area that actually forms the barrier. If I simplify it a bit, it's kinda like P and N regions diffuse into one another a little and that forms the barrier. If there is distance between them, it won't work. There are a lot of materials that explain physics inside diodes in relatively simple words (like me but actually correct and smart) \$\endgroup\$
    – Ilya
    Dec 6, 2021 at 15:52
  • \$\begingroup\$ @Ilya So, what about the cases where we (in UG courses) assume PN-junction diodes to have abrupt junctions? (an ideal diode) \$\endgroup\$ Dec 6, 2021 at 16:07
    \$\begingroup\$ @Jonathan_the_seagull No, they can't. Holes can't travel through metal, they recombine with electrons immediately. \$\endgroup\$
    – Hearth
    Dec 6, 2021 at 17:29
No. What you show would behave as 2 resistors in series.
Note that PN junctions in a semiconductor rely on dopings within the same crystal structure, i.e. monocrystalline silicon.
Your picture shows two independent crystals.
  • \$\begingroup\$ But, what about the ohmic contacts? \$\endgroup\$ Dec 6, 2021 at 14:29
    \$\begingroup\$ they're just that – ohmic contacts. What you've drawn is really just two separate resistors. (and that's good! Though experiment: we both agree the contact-P+-contact component doesn't do anything special, right? so, why should the whole thing suddenly behave differently when, 2km down the cable, someone attaches a contact-n-contact component? \$\endgroup\$ Dec 6, 2021 at 14:45
  • \$\begingroup\$ @MarcusMüller Do you mean to say that the device will behave like a diode? \$\endgroup\$ Dec 6, 2021 at 15:49
    \$\begingroup\$ no, the opposite. \$\endgroup\$ Dec 6, 2021 at 15:51
