I am wondering if there is a way to extract the Nodal admittance matrix of a very complicated circuit using LTspice. Like draw the circuit or automatically generate a netlist (in the case of a very complicated circuit -using python for instance-) and then ask LTspice to compute the Nodal admittance matrix. After all it is what is does to solve the circuit, right?
Thanks in advance :)
  • \$\begingroup\$ Is the circuit linear? SPICE parses a conductance matrix and uses Gaussian elimination to solve for node voltages and branch currents. \$\endgroup\$
    – Ste Kulov
    Dec 8, 2021 at 17:48
After it is what is does to solve the circuit, right?
That is incorrect.
No simulator that I'm aware of solves circuit model problems by understanding anything about admittance matrices (or S parameters etc. for example). Simulators use entirely different algorithms altogether.
No, that isn't likely to be possible. Of course, you can take the AC analysis results and fit them to a formula involving s and that might be of some use (trial and error needed). Then you are a little closer to finding the matrices.
Here's a Q and A that might help you understand how simulators work. Simple extract: -
The general equations produced are nonlinear differential algebraic equations which are solved using implicit integration methods, Newton's method and sparse matrix techniques.
  • \$\begingroup\$ Understood, thank you! \$\endgroup\$
    – Wallflower
    Dec 8, 2021 at 11:15
