I am trying to build a suitable pull-switch for my invention. Inside the switch, there is a tiny metal plate. When the user pulls the switch, this metal plate gets close to and makes contact with two metal structures and forms a closed circuit which is connected to a digital pin on an Arduino.
The problem is that I need this to function for up to 10 million cycles or more, and I'm neither a eletrical nor a mechanical engineer so I have no idea if it will hold that long. I have designed the two metal structures so that there should still be plenty of area in proximity to the metal plate (less than 1 millimeter away) after expected bending, wear and tear, but apart from that I have no idea what other problems I might encounter.
My three questions:
Are there any other issues I need to consider for 10 million cycles?
Can the Arduino handle that many cycles?
Suggestions on suitable material for the metal plate and structures?
