I have an HP motherboard that has some SATA connectors that I'm not familiar with. What kind of connector is it?
  • 4
    \$\begingroup\$ That is definitely not a SATA connector. Probably a power connector of some sort. What exactly do you want to know? The pinout, the model of the connector or what? \$\endgroup\$
    – Klas-Kenny
    Dec 8, 2021 at 20:31
  • \$\begingroup\$ Are you sure you posted the right picture? \$\endgroup\$
    – Oskar Skog
    Dec 8, 2021 at 20:59
    \$\begingroup\$ is that on the motherboard or on a power supply? \$\endgroup\$
    – jsotola
    Dec 8, 2021 at 23:49
4 Answers 4
That looks to me like a fan connector.
Source
  • \$\begingroup\$ It's a different connector than what's used for case and CPU fans. But I've seen that kind of connector on graphics cards and laptops. The color scheme looks typical for a PWM fan. \$\endgroup\$
    – Oskar Skog
    Dec 8, 2021 at 21:11
  • \$\begingroup\$ Your answer could be improved with additional supporting information. Please edit to add further details, such as citations or documentation, so that others can confirm that your answer is correct. You can find more information on how to write good answers in the help center. \$\endgroup\$
    – Community Bot
    Dec 9, 2021 at 0:23
HP among others have used custom non standard cables for sata data and sata power depending on the use case.
That JST connector is likely being used for SATA power from a motherboard connector. It looks like a JST PH 4 pin 2.0mm pin to pin width. The other side is probably a molded micro sata 17 pin connector with both data and power (I'm assuming)
  • \$\begingroup\$ I should have been more specific in my post. This is for SATA power and the other end is a 17 pin connector. I'm just trying to find a cable. From your response I'm looking for a JST PH 5 pin to 17 pin sata power cable. Found one amazon.com/2-0mm-Small-15Pin-Supply-Industrial/dp/B08FNW6HNJ. \$\endgroup\$
    – blfinche
    Dec 8, 2021 at 21:35
  • \$\begingroup\$ @blfinche 4 pin to full size sata power? The picture you include is 4 pin not 5, and there is a difference between sata power slimline sata power and micro sata power connector sizes \$\endgroup\$
    – Passerby
    Dec 8, 2021 at 21:50
thats no kind of sata. The first SATA version supports 1.5 Gigabits/s that would not work with the cable shown in your Photograph.
That is a JST PH female wire-to-wire connector housing, 2 mm pitch (as identified by my connector identification utility).
JST PH connector
