I've been doing some research on RF antenna design considerations but haven't really found anything close to the situation my device will be in. I am designing a wireless sensor for my FSAE team that will be mounted inside each tire (attached to the wheel rim), similar to this product and reports various measurements to a receiver mounted somewhere on the car. The design process (components, schematic, etc) is pretty much finished except for one area, the antenna.
Since the device will be sitting so closely to a large metal object (aluminum wheel) I am concerned about the effect this will have on the antenna. Below are some other considerations:
- The device is using the NRF52833 (Laird BL653 module with external antenna) and will communicate via BLE (2.4GHz)
- The PCB will be roughly 3cm x 4cm (estimate) with 4 layers, one of which will be a ground plane
- I am open to using any variety of antenna (PCB trace, SMD, patch, whip, dome etc) as long as it is 50 ohm impedance as the BL653 specifies
Now for my questions:
- I understand that antennas use a connected ground plane to aid performance, if I were to connect the PCB ground to the aluminum wheel, would the entire wheel now also act as a ground plane and aid performance as opposed to hindering it if it were disconnected?
- Would a flex patch antenna attached directly onto the aluminum wheel surface be desirable? (with or without the wheel connected to PCB ground as mentioned above)
Thank you so much to anyone who has the time and/or expertise to respond!
