I have a new liftmaster (chamberlain) garage door opener that has a wired keypad. The keypad has several buttons on it, but for my purposes I'm only interested in the door open/close and light on/off buttons. I would like to reverse engineer this signal in order to control the door opener and light with an ESP8266.
The keypad is wired with only two wires - meanining the power and signal are sent over the same wire.
Using a scope and an arduino, I have captured the signal which is sent when the door trigger button is pressed. (I used an arduino so I could capture a longer signal than I can with my scope. I used the scope to verify that the arduino is capturing the signal correctly).
My method for capturing the signal is to record the micros()
each time the signal goes from LOW to HIGH or vice versa.
I have observed is the following:
- The minimum pit or peak seems to be ~100 microseconds
- There are three distinct messages that occur when the button is pressed. Notice the voltage is lower on the middle message. I suspect that this might be some sort of confirmation from the opener, and the first and third messages are from the button.
- The message seems to have the same header, but the content changes slightly. Here are two back to back overlaid
- last but not least, you can have more than one button wired in parallel to control the opener
So my question is - what kind of signal might this be?
EDIT: Building off of the observations of @jasen @icodeplenty, I wrote a parser which converts the measured signal into hex. I made a few assumptions:
- the messages are 11 bits long
- the first bit is always low (just a start bit?) and so I ignore it
- the next eight bits are data?
- the last two bits are stop
I then captured 8 passes for three different events and converted that signal to hex (see below).
I cannot discern any pattern here, other than that every event message starts with AA 80 00
Handshake (a message is sent by the button when it is powered on):
AA 80 00 50 3C 6A D4 B4 6D FB BE 25 E8 5C 79 7B B1 DE 95
AA 80 00 65 98 15 6A 58 B2 6C C9 10 28 CC 19 20 05 F2 94
AA 80 00 A5 E4 EE DC 37 69 DA 34 95 14 A3 87 84 4E 61 E8
AA 80 00 21 DC BA 71 FE FD FF FE 19 30 8E 9E 36 6A A1 EC
AA 80 00 41 F0 63 C7 D3 26 49 9A 91 10 C5 0A 52 23 31 E4
AA 80 00 98 A0 06 0D 06 00 12 20 94 84 A3 87 04 4A 61 E8
AA 80 00 18 A0 4E 9F 22 49 80 24 58 9C 2A D6 9F F9 89 62
AA 80 00 46 F0 AA 47 93 6C 49 96 11 74 0E 98 37 6A A3 80
Door Button Triggers:
AA 80 00 06 B8 3D B6 68 93 B6 ED 92 10 D5 0A 53 15 28 40
AA 80 00 80 EC 8F 35 4A 92 24 A9 1A AC 0A 94 2D 6A DA 2C
AA 80 00 00 C0 D6 A7 6E DB B6 CD 92 50 55 0A 52 15 20 50
AA 80 00 6A 30 E5 85 5B 96 65 A9 15 30 CE 14 20 4E D3 20
AA 80 00 AA CC 3A 33 A6 4D D3 54 99 10 86 0C 32 07 12 30
AA 80 00 24 98 70 E7 7E FF FE 9D 11 34 1C 98 36 4E B2 34
AA 80 00 44 E4 8F 51 13 24 48 E2 96 10 87 0C 32 4E 10 30
AA 80 00 91 F0 F5 E0 08 02 20 E0 18 28 4F 9F 2D 4F 80 2C
Light Button Triggers:
AA 80 00 04 AC 58 AA 7C DB B7 6D 10 60 CE 39 60 4C B0 A0
AA 80 00 A6 D4 A3 9F B7 25 5B 96 6A C0 F5 63 52 95 61 E1
AA 80 00 99 40 C6 54 21 01 12 20 A9 84 EB D5 A4 6A 51 C6
AA 80 00 42 F0 61 8F 9B 34 49 9A 64 CC 31 E3 DF B5 6E 8D
AA 80 00 65 98 35 31 DA B2 6C C9 08 64 DC BB 44 DD B0 E5
AA 80 00 0A CC 98 14 ED FB BE 6D 86 5C 1C 28 7B DC 2C 39
AA 80 00 02 4C 0E 54 2D CB B6 6D 06 7C 5C 38 7F 95 BE 3D
AA 80 00 A9 D4 E3 1D B3 6C 59 96 00 60 CE 39 68 DE B4 E9
AA 80 00 80 C0 87 19 4B 92 24 09 81 18 57 2E 1B 95 2C 39
EDIT 2
I found a python implementation of Security+ 2.0, which is the wireless rolling code protocol implemented for the remote buttons. I'm not a python expert, so reading the code is a bit of a challenge. I'm hoping that the same protocol is used with the wired buttons and this library might offer some clues on how to read and transmit the necessary signal.
There is also a patent for Security+ 2.0 which explains a bit about how it works.
Edit 3 I found a program called sigrok PulseView which has a uart decoder plugin. I tested a bunch of recorded samples and found some consistencies which leads me to believe that
- It is in fact uart 9600 baud as @Jasen originally suggested
- I do not know if its LSB or MSB. I left the default LSB decoding in from PulseView
- The data is obfuscated or encrypted and this is a dead end for now
FINAL EDIT for future readers:
I have succeeded in solving this puzzle. I have released an esp8266 shield and a open source solution for controlling Security+ 2.0 doors.
