I'm designing an electric furnace to melt aluminium. I'm planning to use the heating element from an electric oven.
I'm aware that the melting temp for aluminium is lower than copper BUT I don't want to fly too close to the sun. So as an added precaution to stop the copper wires from overheating I'm planning to use stainless steel intermediaries between the copper and nichrome connections (instead of using a good crimp to insulate the copper).
Could using these intermediaries slow down the speed at which the element heats up (in comparison to other methods?) If yes, would it be possible to calculate the extent to which the heating process would be slowed down?
Thanks
