What is this component? Words on it say something like:
DUIULER
0.1 ? +- 23%
250V 50~ WKG
TL
Where the "?" is a literal blob of ink that could be anything.
In circuit it lies across the phase and neutral lines, in parallel with an enormous chonking ceramic horizontal rheostat-like resistor-thing. (edit turns out it is a carbon pile resistor in two stacks, with a ceramic housing.)
The outer surface is slightly tacky, but that might be the kapton-like tape around it.
When measured, it returns a value of 15.80 microfarads, but take that with salt.
In situ it looks like this:
Background
I have a 1957 Singer 201K sewing machine that has had a motor kit retrofitted. It has worked well for decades, but in the last few years the pedal started getting hot, and it once started sewing all by itself.
Web searches suggest this is a
- Noise supression capacitor and is redundant in the modern world without AM radio, can be safely removed.
- Smoothing capacitor, again redundant given its not the 1950s any more.
- It might also be a snubber to help protect the resistor-block.
Links:
Results: I have deleted the capacitor, and the sewing machine runs perfectly without it.
I've also cleaned the contents of the ceramic carbon pile resistor, and that was very dusty and dirty. There's over a hundred carbon disks inside it, of which ~5 were broken. Cleaning all the carbon off brass contacts has also helped enormously, and the pedal does not get as hot. I also am running the pedal on a scrap of wood, not on the carpet.
