I am a newbie in electronics. I was trying to replicate this traffic control diagram:
my basis
I recreated the circuit in Multisim using 2 clocks and an AND gate, the 3 LEDs light up:
multisim circuit with and gate
If I replace the AND gate with a 7408 IC, the green LED does not light up anymore and I am not sure why.
I put the 2 inputs and 1 output wire according to its pin diagram and I connected the VCC and ground.
I can't figure out why the green LED won't light up.
    \$\begingroup\$ Welcome to the EE Stack Exchange. As soon as you start using net labels in EDA software instead of routing wires, your confusion will immediately reduce by 50%. \$\endgroup\$
    – Syed
    Dec 14, 2021 at 9:22
    \$\begingroup\$ The above comment is not generally true IMHO \$\endgroup\$
    Dec 14, 2021 at 11:28
  • \$\begingroup\$ Which IC are you using for the D-type flip flops? \$\endgroup\$
    – Finbarr
    Dec 14, 2021 at 11:54
  • \$\begingroup\$ Thank you all for your answers, it also now worked grounding set and reset \$\endgroup\$
    – elsa anna
    Dec 14, 2021 at 12:32
Forget about the 7408 and...
Ask yourself what the reset pin on the D type flip flop does when it is set high: -
Fix the basic circuit first.
Contrary to your assumption, the 74LS08 supply is not connected to the 5V VCC supply.
TTL logic is not a good choice for driving LEDs, particularly green, blue, or white LEDs.
TTL logic families have a very weak ability to source current and their output voltages for a logic 1 are significantly less than 3V. I would expect that your red LED would glow weakly but green would not be illuminated at all.
You also need to remember that trying to drive an LED with a TTL logic gate is likely to cause the gate's output voltage to be an invalid logic level. If you use the output of a gate to drive an LED then don't use that output as an input to any other logic gates.
The best idea is to use a completely separate driver for LEDs. Add an open-collector TTL chip like the 7406 or 7407 or use discrete transistors to drive each LED.
