I'm having the following circuit: Diagram
Where TWL6030 is a DC-DC buck converter and INA219 is a high side current sensing circuit. INA219
My problem is with the power sources,Vbat and Vs are two different (no common ground) power supplies and Vs is a cheap noisy power source.
Is there a problem of having the common ground between INA219 and TWL6030?
Is the noise of Vs going to influence the functioning of the buck converter?
No problem on both counts. But:
a) You'll get more answers if you draw schematics that are easier to review by following common conventions: Rules and guidelines for drawing good schematics ... notably, general flow of action from left to right.
b) The noisy VS could well affect the INA219. So if the measurements are worth taking, it would be worth fixing that so that it's protected from going outside the allowed Vs range and it's reasonably smooth... this should only take a capacitor or two, perhaps a regulator, depending on the problem.
c) If by "noisy power source" you actually mean a power source with a noisy ground, then you may have more to think about, both with respect to contributing noise to whatever's downstream from the TWL6030, and also to the computer connected to the I2C interface (which will also share a ground with this apparatus).
Hope that helps.
| improve this answer | |
