there is already a electromagnetic brake. I'm thinking to use a electromagnetic induction as brake. is it possible?
    \$\begingroup\$ See "regenerative braking" or "back EMF braking". Connecting a small-value high-wattage resistor across a motor is a crude but effective inductive brake. Note you also need a mechanical "parking" brake. \$\endgroup\$
    – pjc50
    Mar 6, 2013 at 15:31
  • \$\begingroup\$ @pjc50 How is a resistive shunt an inductive brake, or regenerative? \$\endgroup\$ Mar 6, 2013 at 15:45
  • \$\begingroup\$ The motor is inductive. \$\endgroup\$
    – pjc50
    Mar 6, 2013 at 15:53
  • \$\begingroup\$ my design of brake rotor is like a rotor that slots are not skewed. I read that rotor slot are designed skewed to prevent motor locking. Maybe this locking serve as braker. is it right? \$\endgroup\$
    – allen a.
    Mar 6, 2013 at 16:34
Cars, electric trains, elevators, modern ones all use regenerative braking. In this case the electricity generated is fed back into batteries or the mains grid.
Another example is an electronic controlled hand drill / screwing machine. When you release the control push button the motor is effectively shorted and is in turn used to brake its own rotation and it stops spinning very quickly. This is especially essential with screws as you would damage them or the material if you run them too deep/tight.
Regenerative braking @wikipedia
Regenerative braking @howstuffworks
