I've seen below 555 circuit which produces a square wave of 50% duty cycle. I am quite new to electronics and I saw Ben eater's 555 timer tutorial where he used discharge pin for capacitor discharging. One Resistor was very very low compared to Second resistor and created 50-ish% duty cycle. I've seen below circuit from Tutorial and In below circuit Charging and discharging is being done on output pin, when it's low capacitor is sinking into it and vice versa. It's okay but can anybody explain the working of R1 in below image? Article says that
Resistor R1 is used to ensure that the capacitor charges up fully to the same value as the supply voltage
But when capacitor voltage becomes > 2/3VCC, it will trigger capacitor discharging so capacitor will never reach full VCC. And also what if we do not use R1 at all? will is suppose to work?
Excuse my lack of knowledge on subject as I am new and also excuse my bad english.
