Reading this application note about timing for enable RS485 transeiver, I read that I need to ensure a time called "bit time", which depends on the baud rate, for example the document shows an example:
using 230400 baud rate the bit rate is 4.34 µs, but the document doesn't specify how to calculate this value
How can I calculate it?
The application note is here: https://www.st.com/resource/en/application_note/cd00249778-managing-the-driver-enable-signal-for-rs485-and-iolink-communications-with-the-stm32s-usart-stmicroelectronics.pdf
