I have this ADC driver circuit:
There is a passive filter downstream of the driver which works as desired. I'm focused here on the active filter. When I run AC analysis on this circuit configured for a differential input I get the desired and identical frequency response at Vout+ and Vout-
However I need single-ended input. I've configured the circuit in LTSpice like this:
Running AC analysis there is a difference in the frequency response between Vout+ and Vout-
How can I modify this circuit to provide the (symmetrical) frequency response I get with differential inputs using a single-ended input?
